Fuse for DRL's?
When you open the hood, the fuse box is under the driver's side engine plastics.
Remove that, open the fuse box and look for a small rectangular fuse panel closest to you. Pull it out and look for a small blue low-profile 15AMP fuse, which I think is the fuse closest to the driver.
If you have the VLED DRL kit, be aware that any long-term use of the hi-beam will blow the fuse! Buy a $5 pack of these fuses at Autozone, you'll need them like I did!!
