Last edit by: IB Advertising
Browse all: Exterior Guides
- How to Install ISF Rear Bumper
Step by step instructions for do-it-yourself repairs
Rear Bumper Reflector Removal?
If I remember correctly, there are 2 screws inside each wheel well, up high, 1 on the bottom of the bumper on each side behind the wheel and 2 in the middle of the back under the license plate. You also have to take off the back metal load tie downs (they are bolted in, pop a plastic cover in the middle to get to the bolt), both top net hooks and pop off some of the "rug" on the inside of the trunk (if you have to access the wires). You also have to take the plastic cover off the lip of the trunk by the bumper to get to some of the clips. that has 3 plastic clips and then pops off. You will also have to pop off the "tow hook" cover and get to a bolt behind each one.
Once you remove all the screws and bolts from the bumper, the top lip pops straight out if pulled with some force, but don't bend it. Get in close to each pin and pull straight out. You can see the black plastic on the side of the car where the top lip clips in.
Also, don't pull the bumper off too quick, the backing sensors are clipped into the bumper.
Hope this helps somewhat. Let me know if you have specific questions.
do those replacement LED strips look any good? considering buying them but id like to see a few more pics, and anyone else's review. ive seen the lenses come in both red and white on ebay.
Haha...I guess no one really cares about answering your question. I think it was asked a couple times. I was also curious since I saw them on ebay. I'm think I may take a shot and order them from ebay.
Sorry, I haven't been on the boards in a bit. I'll take some pictures and put them up tonight. I have the white lens with red LEDs and they look great. I'll try to get a picture both during the day and at night.
