Driver Door ratchet Assembly Issue
Old 10-17-12, 09:36 AM
g356gear
g356gear's Avatar
Default Driver Door ratchet Assembly Issue
My driver door has been getting progressively worse with a click-pop sound every time you open or close the door. I hit it with grease but it didnt seem to help much. I pulled the door panel and removed the assembly and took it to the dealer for a price.....$230 bucks! Needless to say it is a trim part that is not covered under warranty. I am wondering if this is a common part from Toyota and could be purchased through a Toyota dealer for less. Any ideas?
Old 10-17-12, 09:51 AM
Boma
Boma's Avatar
Wow, any idea why it started giving you problems? Wear and tear?
I would check Sewell or go to a local junk yard and pull it off a regular IS.
Old 10-18-12, 04:02 PM
g356gear
g356gear's Avatar
Pretty sure it was just wear and tear, It got progressively worse over the last few months. Checked the local yards and nobody has any wrecked IS###'s
Gymniac
10-12-11 12:04 PM
msrdude
04-18-11 09:19 AM
93ls40082
18
01-22-10 08:06 AM
marksexton
05-17-07 08:35 AM
Quick Reply: Driver Door ratchet Assembly Issue
