KW V3 question
Just saying I could feel your pain about finding out that you have to cut your OEM top hats and can't put them back to stock AFTER you already committed the money and had your car's suspension disassembled at the shop. I have been there before, not with suspension, but with many mods on many different cars. It's always a facepalm moment when something ends up being more extensive and expensive than you originally planned and you think, damn, I should have read about this more to know what I was getting in to.
Or maybe that's just me.
I would recommend purchasing a set of additional top hats so you don't have to worry about it. Keep an eye out on the classifieds and you can prob pick up a set. That's what I am doing/did.
You might have the option of going with an aluminum top mount also rather than the OEM stuff. I would contact KW to check on that.
Yes the reason KW V1-3 all use OEM top mounts because to TUV regulations in Germany and surrounding.
Tech Info Resource
How is that news? BTW, did you weigh your car or just quoting the 'Net sources?
If you weighed it, yours is a tad on the heavy side.
![](https://www.clublexus.com/forums/attachments/is-f/143520d1241542006-5-0l-v8-versus-5-7l-iforce-v8-is-f-corner-weights.jpg)
check out post #250 on RCB/s build thread. https://www.clublexus.com/forums/is-...-thread-3.html
I wonder if it can be modded to work on the KWs.
