Battery suggestions
#76
#77
Ditto here. I think my OEM 2008 battery is on its last leg after 8 years as it is starting to hesitate on start.....picking up a Bosch AGM at lunch today for about $150ish.
Update: so the battery has a sticker saying it was built in 2013...should I be worried?
Also, who the hell designed the battery clamps? I now have lost 2 of them. Fell straight down underneath the battery bay into purgatory...ugh
#78
After studying and looking for batteries for a month or two now, I also got the Bosch Platinum Series AGM Battery Group Size 24 for my 2012 LEXUS IS-F, but I missed the 35% off! I still got the 25% off. I learned adding the battery to the cart doesn't save the price! It was like 166ish. I didn't want to lose any of my settings with the electronics memory and radio stuff so I used two sets of battery jumper cables and the old battery to keep constant power. It was a PITA, not much room to work with, but it worked. Last time my battery went dead I lost most of my settings and had to use the key to get in it. The battery was a perfect fit except the vent tube on the top left side bowed the plastic battery side cover just slightly. It cranks really fast now, my old battery was borderline shot and I had to keep it on a maintainer. I only drive it maybe once a week. Don't knock the two hold down bracket bolts/screws loose putting the new battery in or break the plastic wire holders that connect to the battery shell/cover on the positive side, they come off or open pressing the tab. It looks good with the blue top. BTW, I think it is the same as the Exide Edge FP-AGM24 Flat Plate AGM Sealed Automotive Battery they sell on Amazon, but I'm not 100% sure. Also Lexicon72, I got my battery home and noticed it was shipped on March of 2014! WTF? I took it right back and got a fresher one that was shipped six months ago, I can live with that. Damn I never noticed a "Build Date" Oppsey. They would have ordered me a fresher one than that, but I didn't want to wait. This is what sold me on it: "Bosch Platinum AGM is backed by the confidence of a full 4-year free replacement warranty. Need a jumpstart? Bosch Premium Performance car batteries promise a 3-year FREE emergency jumpstart!" Pep Boys.
#79
#83
13.5 is acceptable. Its a bit on the low side, but still acceptable.
#85
also, just to note, I only changed the battery today because I was having slow start issues and the battery would die after about 4 days of no driving. I'd hate to see my alternator going out at 47k miles. I suppose I can pull out the alt. and bench test but I'm too lazy to do that.
#86
That's odd. I see 14.4v on my beater cars at idle. Ill check my FRS now.
FYI.... if you have to replace the alternator, you will most likely have to have it rebuilt. When mine went out, i searched everywhere for a remanufactured one and couldnt find one anywhere. I called the dealer and they informed me that according to their system, they are only showing new ones for sale at a price of something stupid like $1800. I said screw that, took it out, found a shop that rebuilds them and had it rebuilt for like $300.
Good luck!
#87
#89
ETA: I have updated my post with some new information in case it is helpful to anyone else in the future who finds this thread in a search.
I'm in the throes of replacing the battery in my 2012 IS-F and have run into the same height issue. The Die Hard I bought is about an inch shorter than the OEM battery.
![Battery suggestions-o88gvwk.jpg](https://www.clublexus.com/forums/attachments/is-f-2008-2014/492307d1683158853t-battery-suggestions-o88gvwk.jpg)
The Die Hard didn't come with any spacers for the hold-down - hopefully they are sold separately.![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
Update: I went back to Sears to return the Group 34 battery I bought and get a Group 24 which has been discussed in this thread. Turns out the battery I bought is supposed to come with a 1" spacer block that attaches to the bottom, but the douchebag salesman forgot to give it to me.
With the spacer block in place the Group 34 battery fits perfectly against the hold-down bar.
The other issue I haven't seen discussed is the plastic sleeve that slides down over the top of the OEM battery and has the hold-down clips for the wiring haresses on the side:
![Battery suggestions-pgpmipz.jpg](https://www.clublexus.com/forums/attachments/is-f-2008-2014/492308d1683158853t-battery-suggestions-pgpmipz.jpg)
Because the Die Hard has little plastic clips on the side where the carrying handle attaches this sleeve will not slide over the top of the Die Hard. How did y'all deal with this? Did you just ditch the sleeve and leave the harnesses flapping in the breeze, so to speak?
![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
