Battery suggestions
#121
#123
Sounds a little too inconvenient for me personally unfortunately but the weight savings are undeniably awesome.
#125
Tech Info Resource
How does that work? It shuts off all the time and you have to reset it all the time, or it only shuts off when the charge drops to a certain level and you have to manually reset it occasionally?
#127
#129
That is serious coin for a battery.
#130
Tech Info Resource
Odyssey Extreme is what I have in my ISF. Best battery I have ever owned in any car.
#134
Thanks in advance.
#135
Well. 3 years and 3 months and my Bosch AGM battery finally died. But note that it was actually built 3 years prior to purchase (ugh - didn't notice until after I installed).
Telltale signs over the last 2-3 weeks were slight hesitation upon starting and my dashcam voltage cutoff monitor (Blackvue Power Magic Pro) was cutting power to the dashcam right away (indicating < 12v).
Got 11.1 volts last night and then not surprisingly it finally didn't start this morning.
Got a free replacement (has a nice 4 year warranty) at Pep Boys. Though interestingly it no longer shows the Bosch AGM Group 24 battery as compatible.
