New Sponsor (Adam's Rotors)
other than our AR braking division, adam's rotors is a 1-piece replacement rotor...
thus, being made to order, pattern is where you can effect performance.
we designed our exclusive double slotting with performance in mind and have run it on many track cars & have even helped w/an endurance race team.
increased heat dissipation, added bite, and glaze avoidance are the benefits to such a pattern.
we also offer performance pads & stainless brake lines.
that package along with a set of our AR race pattern, you'll have great results.
our IS-F orders are thru the roof...thanks for the support everyone!
I noticed on your website that the pads you offer are Stoptech pads.
How do these compare to stock brembo pads?
As far as the steinless steel brake lines. Do you think that these are
better than the stock lines, I read somewhere that stock lines are Kevlar-coted
therefore better. I would appritiate your expert opinion.
Thank you for your time.
realize we retail these products and offer them for ALL applications and pair them as bundles with our rotors...
I cannot speak specifically per car/model or their OE offering comparison having not owned/driven each, but the Stoptech compound is a great, realistic daily driver performance pad that has trumped every factory given pad I've seen. the Kevlar vs. stainless line question I'm not certain about, but that makes sense...these are typically used to swap out rubber lines most cars have standard that are far inferior.
more found here about the two and why we offer them: www.adamsrotors.com/pads
