225/40r18 on the front ... too small?
Old 11-13-12, 12:30 PM
Ascari_2
Ascari_2's Avatar
Default 225/40r18 on the front ... too small?
I am about to pick up some winter rims/tires for the F and the package comes with 18 G-Spiders with 225/40s on the front and 255/40s on the back. I know the back diameter matches up to what is recommended, but the fronts end up being about an inch smaller than the OEM size. So the question is, would it be s problem to have a smaller diameter tire on the front? Or will I be ok. Another question is would this throw off the odometer or speedo reading, or are those calculated off the rear wheels.
Thanks
Old 11-13-12, 03:39 PM
MisterSkiz
MisterSkiz's Avatar
not sure..but your overall diameter will be smaller..might look goofy in wheel well...my g spyders have 225 45 on the front.
Old 11-13-12, 05:56 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 4,006 Likes on 2,427 Posts
Speed is calculated off the rear wheels only. I found this out when bedding in the rear brakes on jackstands.
Old 11-13-12, 09:42 PM
Ascari_2
Ascari_2's Avatar
Thanks guys. Would that mean that the odo is also off the rears?
Old 11-13-12, 09:57 PM
ISF77
ISF77's Avatar
From what I've seen 225/45 is the recommended size up front. What is the width of your rear wheel? 18x8? I'm looking for a winter set myself. Not sure how an 18x8 rim would fit a 255 sized tire and if it would be too stuffed..
Old 11-14-12, 02:05 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
255/40/18 and 255/35/19 are so close in diameter there's nothing to talk about.
Old 11-15-12, 07:38 AM
Ascari_2
Ascari_2's Avatar
Lobux, the rears are perfect, so as long as the speedo and and odo are run off of the rear tires, I'll be ok. I just don't want an incorrect readin off the fronts since they would be about an inch smaller overall.
Old 11-15-12, 05:45 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
The VSC might not like the smaller fronts, but the speedo won't care at all.
Old 11-15-12, 07:43 PM
ToothDoc
11 Second Club
ToothDoc's Avatar
The VSC didn't care when I had 225 40 18s and 255 40 18s in the rear (1" difference in tires). Eventually, I wore out my old IS350 front tires and went up to the right sizes. The thing that bothered me was the wheel gap was fugly.
Old 11-15-12, 07:55 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Ah - I missed what you were getting to - the odometer and speedometer use the same signal source, so if the speedo works correctly, the odometer will also work correctly.
lui16blue
09-08-18 07:00 AM
P128sniper
10-23-16 03:57 PM
jminor
10-30-13 10:25 AM
chikoo
11-12-10 01:57 AM
DaveGS4
Wheels, Tires & Brakes Forum
09-03-02 02:15 PM
Quick Reply: 225/40r18 on the front ... too small?
