Plasti dipped my emblems and grill
#32
I sprayed the emblems directly on the car, the plasti dip when dried just rubs right off if you gently rub your finger over it or a micro fiber towel and does not damage the clear coat. Before you spray just be sure to wash the area with soap and water and some rubbing alcohol and use painters tape to tape off an area around it so you can get a decent amount to pull up and gently pull away from emblems.
#33
chrisCARL0S
IS - 1st Gen (2001-2005)
02-03-06 11:22 PM
