Plasti-Dip Rear Bumper
Old 05-19-14, 08:27 PM
Sean
Sean's Avatar
In it's liquid state I'm sure it is. Dried and cured it should be no more flammable than the rest of the bumper. We've had at least one guy plastidip his exhaust tips without issue .
Old 05-20-14, 05:01 AM
torxuvin
torxuvin's Avatar
Originally Posted by Rossi
I believe, plastidip is very flammable. I would be very careful to be spraying that area of the car.
It's not to my knowledge. I had an diy exhaust plate on my corvette that had a black plastidip background. No issues with the exhaust temps. Also had the diffuser done. That said I am not planning on using it with the F. Thought about the window trim but I'll probably go vinyl.
Old 05-20-14, 05:53 AM
Lets Drive
Lets Drive's Avatar
Originally Posted by rselby
I like that...gonna do mine like that( maybe black) IM not sure yet
Plasti-dip is a nice, cheap, temporary method to see if you like it. I dipped mine first, then handed it over to my painter to paint the rear in a satin black.
Attached Thumbnails Plasti-Dip Rear Bumper-rear-1.jpg   Plasti-Dip Rear Bumper-rear-2.jpg
Old 05-20-14, 02:44 PM
rselby
rselby's Avatar
^^^^^^^^^ That looks good, that's what im talking about....may just go the paint route( like the satin)
Old 05-20-14, 07:34 PM
Weapon F
Weapon F's Avatar
Some misinformation here regarding plastidip I did my rear bumper, front bumper, and fender 8 month's ago. My car is DD and went through one of worst winters in years single digit temps, salt,sand, freezing rain etc and plastidip held up perfectly. As far plastidip running when you apply it that only happens if your to close or hold it in one spot to long. If you end up with rough finsh you applied it wrong. Typically that happens when your to far away from surface plastidip is being applied to. Once again comes do to not properly using product. It's very easy to get clean lines, the trick is to remove tape while plastidip is still wet. Plastidip will leave you with matte finish but if you use any wax or even spray detail wax you end up with satin like finish. It not for everyone but one of best things about plastidip is that when you get tired of it just peel it off. Last two pics were taken today to show how well its held up. Pic's of my F
Old 05-20-14, 09:21 PM
iH8RICERZ
iH8RICERZ's Avatar
that actually came out super clean!
Old 05-21-14, 11:25 AM
hyb1212id
hyb1212id's Avatar
That is pretty clean. Thanks for sharing. Makes me want to reconsider trying out the plastidip.
Old 05-21-14, 08:51 PM
Weapon F
Weapon F's Avatar
Some more pics
This one with s4play diffuser
Old 05-21-14, 08:57 PM
Weapon F
Weapon F's Avatar
These pictures show you can get nice clean lines
Achilles07
01-17-17 09:48 PM
joeyb
NX - 1st Gen (2015-2021)
02-24-15 02:52 PM
ziggy1
RX - 3rd Gen (2010-2015)
05-23-10 06:59 AM
Musiqizme
06-17-09 04:13 AM
RLand
RX - 1st Gen (1999-2003)
09-28-01 05:38 AM
Quick Reply: Plasti-Dip Rear Bumper
