Squeaky instrument cluster
11 Second Club
Hey, it's getting colder here in Chicago and EVERY winter for the last three or four years I notice I get a squeak. It's finally has gotten to me so armed with some black felt, I went searching for it.
I think I found the parts that were rubbing causing the squeak. It's actually the black plastic frame rubbing on the clear plastic in front of the instrument cluster. If you gently press on it, I hear this squeak, squeak, squeak. The problem is, how do I go about stopping it?
Just to verify, I put just a small amount of windex on the part that seemed to be rubbing and voila! My squeak went away - but I know tomorrow when the sun comes up, I'll have my squeak back.
Anybody else have this? Solutions?
I was actually thinking of putting a VERY small dab of oil right on that one little contact point so the friction wouldn't cause it to squeak anymore.
I have had this same issue for 15,000 miles. It's very annoying. I found if I push hard in the left hand cornor it will go away for that time of driving but back the next day. One of these days I will pop the dash off and fix it.. The Lexus tech that I'm good friends with said he would replace it. Just don't feel like driving 1 1/2 hours over a squeak lol
Maybe this weekend I'll pop it off. I'll be sure to post what I do.
omg yes.. finally, i've taken my car to the dealer numerous times to report this but they never fixed it. Guess I'll have to do it myself.
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
that's funny. im 10 mins from chicago too and soon as it hit 30's my cluster began to squeek and omg im ready to pull my hair out. I am going to try your random magic and see how this goes lol
11 Second Club
How to remove the gauge cluster trim piece
Squeak fixed. I removed the trim piece and applied thin felt strips to all contact areas around it.
There are 4 screws holding the cluster trim piece in place. Two at the top and two below. The ones at the top are easy to remove and are actually screw clips and the two below are actual metal screws.
Here is the link I followed that shows you how to gain access to the lower two screws.
https://www.clublexus.com/forums/6664323-post76.html
The two top screws to remove
One of two lower screws to remove
Final lower screw to remove
Yup I just jammed a black piece of folded up paper between dash and gauge cluster bezel right above the steering wheel just keeps the two pieces from rubbing that's my cheap fix lol
