Warning beep?
Old 12-07-12, 01:56 AM
BULLIT
BULLIT's Avatar
Default Warning beep?
I was wondering if there is a way to stop the warning beep when you need to change gear on upshifts in manual mode or when you want to change down gear and car won't let you, I understand this is in place to protect from over revving but gets a little annoying.
I have searched forum but haven't found anything.
Old 12-07-12, 06:09 AM
fasttexasz
fasttexasz's Avatar
Think your out of luck on this one. You would probably need the special computer the Lexus techs have at the stealership if it was able to be changed.
Old 12-08-12, 02:02 PM
CCLSVTF
CCLSVTF's Avatar
I actually like the beep. I hate it when it won't let me down shift and that beep is like saying, "Denied loser" but I like that there is some tone saying the shift was not done.....
Old 12-08-12, 02:34 PM
2ndGF
2ndGF's Avatar
I never hear mine over the exhaust and stereo
Old 12-08-12, 03:57 PM
VtotheJ
VtotheJ's Avatar
Gawd, how often do you hit high RPM's?
Old 12-08-12, 04:13 PM
anxiouz
anxiouz's Avatar
Originally Posted by BULLIT
...or when you want to change down gear and car won't let you, I understand this is in place to protect from over revving but gets a little annoying.
Since when is not blowing up your engine annoying?
Anyhow, the beep is there to say. There's no known way to disable it. The only time I hear mine is at WOT and at that point it's barely noticeable.
Old 12-08-12, 09:27 PM
BULLIT
BULLIT's Avatar
Thanks for your input I'm fully aware of what the beep is for!
Having come out of a RS5, C63 and M5 none of these had warning beeps. Simply change before hitting the limiter.
Old 12-09-12, 05:08 PM
ISF001
ISF001's Avatar
A lot of the test drivers like the beep as well. Frankly, it doesn't bother me.
Old 12-10-12, 10:41 AM
digger08
digger08's Avatar
As a beginner on a track I valued the beeping, as I tried to keep my focus on entry and exit points and the road and not on my RPM's.
Digger08
juncho
11-28-16 02:32 PM
sorka
11-27-13 11:16 AM
Daber
HS 250h Model (2010-2012)
20
03-19-10 09:04 AM
arpan176
08-13-07 09:32 PM
MattIS
05-02-06 10:10 PM
Quick Reply: Warning beep?
