DIY LED 'stripped' headlight installation
Old 05-05-13, 06:53 PM
hahahaf
hahahaf's Avatar
us canadians have the drl on all the time.
so is it possible to switch the 100% brightness led pin in the harness to the drl location to have the 100% brightness on the auto setting?
or am i thinking about this wrong?
Old 05-05-13, 07:43 PM
digger08
digger08's Avatar
No. You are thinking this wrong. The DRL uses a relay to react to a low voltage drop from the DRL module and turn on. It is basically your high beam voltage reduced in half....which dims the light so you don't blind people in the daytime.
Digger08
Old 05-05-13, 10:31 PM
hahahaf
hahahaf's Avatar
Yes i was thinking this as well after i posted
Digger08
Old 05-19-13, 02:15 PM
hahahaf
hahahaf's Avatar
howdy gents
in need of some assistance
finally got my swell stripped led headlights
putting them in today
I hit the dreaded snag
im trying to copy this exact
I have 18g wire and connectors
everything seems to be correct
hids and turn signals work
I tested the lights and the leds worked before i pulled the pins
I have it grounded nice
but im totally stumped at the moment
any advice ?
please and thanks
Old 05-19-13, 06:24 PM
CalitriSC
CalitriSC's Avatar
Its very easy to get the LEDs at 100% brightness all the time, mine are as well as several others. You just have to switch the right pins.
Old 05-19-13, 06:50 PM
hahahaf
hahahaf's Avatar
100% even with your switch on auto?
I have the swell lights and its my understanding that fuse tap and wire them up was the only way?
Old 05-19-13, 08:28 PM
Murph145
Murph145's Avatar
Yes you would have to do the fuse tap to run them while the switch is on auto otherwise the way calitrisc did and what I did the Hewitt car is make it where you have to have your running lights switched on to have them on and when headlights are on they are on too both 100%
Old 05-19-13, 08:43 PM
hahahaf
hahahaf's Avatar
yeah i thought so
im still stuck
gonna redo some connections and see how it goes
Old 05-19-13, 10:26 PM
Murph145
Murph145's Avatar
Fuse tap method is IMO a better method but more intrusive work but is more true to oem for 2011+
Old 05-20-13, 05:33 AM
hahahaf
hahahaf's Avatar
yes i agree
what gauge wire is everyone using to the fuse tap?
Old 05-20-13, 11:01 AM
Murph145
Murph145's Avatar
^ believe they said 18 gauge
Old 05-20-13, 02:16 PM
hahahaf
hahahaf's Avatar
yes but is that the popular option?
Old 05-20-13, 02:50 PM
Murph145
Murph145's Avatar
I dont think you have many options as far as opinion is concerened lol I say 18 is fine
Old 05-20-13, 06:32 PM
CalitriSC
CalitriSC's Avatar
yea if you want that complete oem type instal lol. i like being able to turn my lights all the way off though if i want to. and didnt have to do any wiring.
Old 05-20-13, 07:49 PM
hahahaf
hahahaf's Avatar
im just thinking
what about the ground that attaches to the ballast then to the side of the light
did you guys with the swell stripped lights switch that over too?
Quick Reply: DIY LED 'stripped' headlight installation
