DIY LED 'stripped' headlight installation
Old 05-28-14, 01:24 PM
  #46
OneSiCkF
OneSiCkF's Avatar
Did you guys need to buy a new led relay to install on the car as well as the high beams back cover? Also, has anyone wired their LEDs to be intermittent when the signals are on such as they are on Audis? Or does everyones LEDs remain lit when the signals are on? Apologize in advance if it sounds like idk what im talking about.
Old 05-28-14, 01:35 PM
  #47
digger08
digger08's Avatar
No...but needed a flasher relay for the turn signal bulbs, reducing from two bulbs to one.
Digger08
Old 05-28-14, 01:47 PM
  #48
Boma
Boma's Avatar
If you meant the LED harness then yes you will need one for each headlight as well as two high beam covers. These are required only if you're buying off of eBay, which typically sells stripped down sets. The flasher relay for the rapid turn signal is optional, it won't affect the LEDs if you don't get it. Also, I don't think anyone has been able to wire it to have the Audi-style turn signal logic, but I'm sure it is possible if someone skilled enough can utilize some relays and clever wiring.
Old 05-29-14, 10:15 AM
  #49
tommigsr
tommigsr's Avatar
Originally Posted by saxqtzk
Dannyk: I didn't have that issue. Everything was working that I could tell (highs, lows, turn signal) once I plugged the headlight connectors. The only thing I'm not sure that's pinned is for the auto level motors which I have yet to see go up and down.
Can you take a picture of your headlamp connectors, I can try to help you or someone can chime in if your harness needs to be repinned properly.
the new headlights with the LED strips do not have the auto level motors (AFS)
Old 05-29-14, 10:41 AM
  #50
MK4Sup_isF
MK4Sup_isF's Avatar
AFS is not auto level. It is for left and right movement as you turn. 11+ has auto leveling, no AFS
Old 06-02-14, 01:20 PM
  #51
OneSiCkF
OneSiCkF's Avatar
Did you guys fit the headlights with the cap underneath on? I believe it doesn't fit on the isx50. Please see the picture below.
Attached Thumbnails DIY LED 'stripped' headlight installation-3dc69304-63f2-46b8-a4ee-cc09e8e642e6_zpsi6703l6p.jpg
Old 06-16-14, 06:36 PM
  #52
Vibes63
Vibes63's Avatar
Questions.
I have completed the entire process as directed, however both my LED light wont come on. Again, you cut the green wires on the led headlights and then ground those wires? Then you cut the red wires on the LED headlights and then connect it to the wire going to the Fuse Tap? I have a Fuse Tap with two slots. What amp fuses do I put? The IG2 has a 10 amp fuse. Any help would be great, as I am so close.
Thanks
Vilash
Old 06-16-14, 07:58 PM
  #53
MK4Sup_isF
MK4Sup_isF's Avatar
Originally Posted by Vibes63
Questions.
Thanks
Vilash
I installed for two cars now, the green is power and the red is ground. Did the test with a 9v battery to confirm before installation
Just add another 10 amp fuse in the fuse tap.
Old 06-17-14, 11:29 AM
  #54
Vibes63
Vibes63's Avatar
Great! That makes sense I keep burning out fuses with ground connected to green and red connected to power. Thanks
Old 06-17-14, 12:04 PM
  #55
Vibes63
Vibes63's Avatar
Does the directions of the amp placement matter?
Old 06-17-14, 12:53 PM
  #56
MK4Sup_isF
MK4Sup_isF's Avatar
Nope!!!!!!!
Old 06-18-14, 05:23 PM
  #57
Vibes63
Vibes63's Avatar
Works amazing!!! Thanks everyone
Old 08-10-14, 10:51 AM
  #58
MEAHT
MEAHT's Avatar
Hey One SiCkF,
What did you do to cover the square opening where the AFS controller with lid goes over? Will not spend 400$ for AFS controller, especially since the AFS feature wont be working.
Anyone else care to chime in?
Took lights out the box ready to install and saw this opening with no cover...worst feeling ever
Old 08-10-14, 10:55 AM
  #59
MK4Sup_isF
MK4Sup_isF's Avatar
Originally Posted by MEAHT
Hey One SiCkF,
That's not AFS controller, that's the ballast to power the HID bulb.
Old 08-10-14, 12:30 PM
  #60
MEAHT
MEAHT's Avatar
Thanks for the quick reply MK4Sup_isF.
Would I be able to buy this part used and still be able to use an aftermarket hid kit?
Found some on ebay for $60 each.
thanks
Quick Reply: DIY LED 'stripped' headlight installation
