So called Pep Boys for quote
Tech Info Resource
Enough of the bashing. If there's something constructive to say, then say it. Otherwise, this thread can just die quietly.
Any continued bashing will be deleted without warning, explanation, or regret.
^^^ the fun has ended.
I guess we have to get back on topic now. Replacing your own spark plugs isn't hard, but it just takes a lot of time due to the tight spaces. You just have to remove the battery to get to the one spark plug in the back, and i would suggest having a set of wobble extensions...3, 6, and 12 inches and you'll end up using all of them. You also need one of those universal joints...i think that's what they're called. Allows for more bending of the extensions and what not. And of course, a spark plug socket.
I did my spark plugs last week, and although it was the most difficult spark plug install i've done (due to how damn tight the engine bay is) the job only took me a couple hours.
give it a shot, atleast 16" worth of extension, a swivel, needle nose plyers, and a normal set of plyers will make the job much easier.
Tech Info Resource
jpv7774
06-26-15 01:02 PM
JETLEX
09-02-13 04:58 PM
ohno
09-03-09 08:38 PM
