KW v3 owners chime in.
Old 08-10-18, 02:17 PM
Rossi
Rossi's Avatar
Installed the KW v3 coil-overs on my 2010 ISF, I must say, they completely transform the car. Once in a while you see the post about what should be your first mod, get some good coilovers, it is an absolute must for 2008-10, shame on Lexus for such a crappy suspension on the early model years. I can’t believe that I put out with the low ride quality for so long. I chose KWs as my car will never see the track. I have been only messing with the ride height, not touching the other two adjustments.
I did the installation myself, not bad, that was my first suspension install, top hats little tricky but not bad.
Helpful link for anyone installing:
http://www.speedhunters.com/2016/09/...kw-variant-3s/
Helpful video:
Old 11-25-21, 12:11 PM
Rossi
Rossi's Avatar
I have my KWs set at the maximum height specified in the manual, which is about 5mm lower than stock (0.2 inch).
I know it is not good to go lower than recommended. What if I want to go tad higher the recommended range (OEM height) any issue or risk of damaging the coilovers?
Old 02-23-22, 07:18 PM
dlin4229
dlin4229's Avatar
M4 GTS uses KW Club Sport suspension... (But, the spring rates are about as stiff as KW V3 for M4)
The below is the suggested damper settings for M4 GTS on street... (I got them from a M4 forum )
Ride height 624mm front, 631mm rear
Rebound 6 clicks front, 7 clicks rear (16 is the softest)
Low speed compression 3 clicks front, 2 clicks rear (6 is the softest)
High speed compression 6 clicks front, 7 clicks rear (14 is softest) <<<< KW V3 doesn't have this... So, you can skip it.
The below is the track setting for M4 GTS...
Rebound 4 clicks front, 4 clicks rear (16 is the softest)
Low speed compression 2 clicks front, 1 clicks rear (6 is the softest)
High speed compression 6 clicks front, 9 clicks rear (14 is softest) <<<< KW V3 doesn't have this... So, you can skip it.
Hope it helps... (Your car could be different)
The below is my setting for my GSF's FIGS Ohlins DFV 16/12K.
Rebound(mainly) & low speeding compression in only one setting: 8 clicks front,12 clicks rear (32 is the softest) which is different but not very different than the street setting for M4 GTS, I think... (I set my dampers before knowing M4 GTS setting)
My setting is stiffer but I think it's reasonable as my Ohlins is already 2 year and 20K mile old... (2 years ago, the setting was 1-2 click softer)
I also lower my tire pressure from 36F/36R to 32F/30R to get some comfort back... (Both my wife and I are 50 something office staff...)
Old 02-23-22, 07:29 PM
dlin4229
dlin4229's Avatar
The blow is some additional information... Enjoy!!!
M4 GTS Technical Information (P.66 for damper settings)
vraa (02-25-22)
Old 02-25-22, 09:35 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,972 Likes on 2,403 Posts
If you want the deep dive, go here: http://farnorthracing.com/index.html
This starts with measuring your chassis and goes all the way through modeling the suspension, determining natural frequency, and setting up the car to perform at championship level.
Noobierice
02-05-19 07:21 AM
SCWB
Suspension and Brakes
06-17-13 06:40 PM
1WILLY1
11-06-12 03:54 PM
s4play
IS F (2008-2014)
37
03-12-11 10:19 PM
Gtti
11-09-09 11:15 AM
Quick Reply: KW v3 owners chime in.
