new in the isf world
Old 12-30-12, 02:17 PM
KOKISF
KOKISF's Avatar
Default new in the isf world
Hi im new here got my hands on a stock 2008 isf black in black so far great , only having issues with my key fob or keyless entry but this is not the reason im here , i was looking onto intakes and read all about different brands and set ups , im for one a true beliver that Lexus created a great intake system and i dont want to get rid of it because i know it should perform better than all others. Ive also heard good things about joe x intake pipe and I agree that the factory duct is restrictive but i havent found any real data of this mod I know esthetics is one of the reason for this being but I dont mind the stocker , what i would like to know is that if its worth it puting a dry drop in with the joe z intake tube ??? what difference should i expect by doing this anyone with just this mod? I dont care much about esthetics or loudness actually i hate the last one so any input will be appreciated. Keep in mind ditching the stock intake its out of the equation!!
Old 12-30-12, 08:26 PM
JDMV8
JDMV8's Avatar
Get a joe z intake elbow
And keep the stock filter or opt for a Tim's
I love the stock intake system as well, and had had my share of aftermarket intakes for the F
Fun, but not efficient!
Unless you want to spray, stick with stock system with joe z or hps tube
Old 12-31-12, 04:43 AM
darbs242
darbs242's Avatar
I would get the HPS intake tube and a toms drop in. It does the same thing but is made from different material so i doesnt heat soak
Old 12-31-12, 04:52 AM
BULLIT
BULLIT's Avatar
If you just put the joeZ or HPS intake tube on do you still get the secondary induction noise at 3600rpm or do you lose it? I am also new to ISF's and still learning
Old 12-31-12, 04:55 AM
KOKISF
KOKISF's Avatar
thanks for the input greatly appreciated will check the HPS!!! one question though, does the oen drop in , is good or should I replace it with a dry one, I know the troubles you run with the oiled!?
Old 12-31-12, 04:58 AM
RobPR
RobPR's Avatar
HPS, AFE's Dry drop in and spray the hell out of it!!!! Saludos Koki!!!
KOKISF
KOKISF's Avatar
I think and im quite sure you will still have it because you are not really altering anything in the intake box, all you are doing is smoothing out a bit more the air flow , thats why the gain is so minimal but ill guess is worth it, i have no plans what so ever to spray so ill stick to the factory oem air box that to me is like a work of art
Old 12-31-12, 04:59 AM
RobPR
RobPR's Avatar
ohh and by the way, welcome to the ISF community. They are all cool people here with a lot of knowledge on our platform.
Old 12-31-12, 05:00 AM
KOKISF
KOKISF's Avatar
whats up bro , 2013 redy to unleash the gray beast?? thank you for the invite and so far im loving it , learning a lot
Old 12-31-12, 05:05 AM
RobPR
RobPR's Avatar
Dyno tunning on wednesday. Looking for the big 600... More than welcomed to come. I'll let you know on which dyno.
Old 12-31-12, 05:25 AM
flowrider
flowrider's Avatar
Received 1,951 Likes on 1,374 Posts
You may want to look at the Takeda as well:
https://www.clublexus.com/forums/is-...fe-takeda.html
https://www.clublexus.com/forums/is-...50-intake.html
https://www.clublexus.com/forums/is-...fe-intake.html
That has been my intake of choice. It is the only conical filtered intake system that retains the stock secondary intake flap.
Lou
Old 12-31-12, 06:04 AM
JasonH42
JasonH42's Avatar
Don't worry, you still get the wonderful sound at 3600rpm unless you fit something that bypasses it like a K&N intake.
I fitted a HPS silicone intake (blue!) - it took literally minutes, very easy - plus an aFe oiled filter and now it really feels like the engine can breathe properly and throttle response seems much better.
Highly recommended mod.
Old 12-31-12, 06:26 AM
BULLIT
BULLIT's Avatar
Thanks Jason. I thought the AFE dry filter was better for ISF or isn't there much difference?
Old 12-31-12, 07:04 AM
JasonH42
JasonH42's Avatar
Well I did a lot of research on this forum first - and thanks to everyone who posts, there's a lot of great info and experiences here - and another user had convincing graphs showing much higher throughput with the oiled version. But whichever is best, I'm very happy with this combination.
Old 12-31-12, 08:51 AM
Evil Teo
Evil Teo's Avatar
stock is the best...if you want to retain the stock setup get either Joe Z or HPS. get a drop in filter from Toms or keep it stock.
here is the thread figs started to compare different intakes...
Quick Reply: new in the isf world
