And the modding begins...
Old 01-11-13, 06:07 PM
  #31
FIGS
The Maker
FIGS's Avatar
The biggest interference is actually the rear bumper to fender junction even after you roll everthing this will still hit. We just released our upper link kit to adjust the top in an out though you will be taking quite a bit out and the camber curve will be much steeper. You would probably need toe links as well. or do a combo of more camber via the LCA plus the upper links.
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old 01-11-13, 08:20 PM
  #32
CalitriSC
CalitriSC's Avatar
Hyper ISF has 19x9.5/10.5 +30 Works with shaved rear fenders and camber in the rear...
Old 01-12-13, 10:41 AM
  #33
Nameless1
Nameless1's Avatar
Thank you Figs and Calitri for the info. That Hyper ISF make me wish I found a white one so much more. Anyway, I found a used set of upper control arms so I'll give that a try. I also went and bought a set of Eastwood fender rollers. Kinda extreme, but i figure that I'd be saving on the labor, and then I can just sell it later for not too much less than what I paid for it, making the cost similar to that of a rental, but without the need to return in within a time period. Too bad no one in the Charleston area does fender rolling. Hopefully this will correct my problem.
Old 01-12-13, 10:51 AM
  #34
shyguyF
shyguyF's Avatar
Hi CalitriSC I'm just wondering what specs of the rear tires is the Hyper ISF rolling ? thanks !
Old 03-20-13, 04:39 PM
  #35
VicTornin
VicTornin's Avatar
Any updates? were you able to make them fit? I just ordered 19x9.5+30 and 19x10.5 +30..
Old 03-20-13, 05:33 PM
  #36
ISFPOWER
ISFPOWER's Avatar
you can make this fit. the white car up top Caltri posted has the same specs.
tires are 265/30 in the rear, run a bit of camber, correct the toe , roll/.shave rear fender and you are good to go. i would rather run a 255/35/19 though
Old 03-20-13, 06:35 PM
  #37
Nameless1
Nameless1's Avatar
The fronts are perfect. They make a little noise when I'm in reverse and full left/right, like the tires scraping on the wheel well liner or something. Rears have been the biggest pain in my butt. Right now, I have the fenders trimmed, pulled and wheels cambered in using both the upper and toe links to about 1.5 degrees. I still rub on big bumps or if I have people in the rear. I think i'm gonna have to camber it in another half a degree to see if that works out. Next time I get a car wash, i'll take some pics. If I could go back in time, I would have got the rears in +37 to +45 range. Would have saved me a lot of money and frustration.
My rear tires look all ate up too from the rubbing. The fender literally cut them up. When i get it all dialed in, I'm probably going to swap the left and right rear tires so that the ate up side is inboard so that it's no longer visible and thus won't remind me of this inconvenience. Of note, my rear tires are 275/30/19. Thinner tires would have helped a lot as well.
Old 03-20-13, 07:33 PM
  #38
ISFPOWER
ISFPOWER's Avatar
1.5 camber is not going to do anything. thats like oem camber
Old 03-21-13, 03:39 AM
  #39
Nameless1
Nameless1's Avatar
Sorry, I meant 1.5 degrees more than stock (2.2 since stock was 0.7 degrees). You can tell looking from the rear and looking at the dirt on the tire thread that the wheels are // \\. It actually looks similar to hyperisf above, but as much. I think hyperisf is running 265/30/19 too which would make it easier to fit under the fenders.
Another thing that I've noticed is that my wheels are pushed more to the rear when they were cambered in. This makes the tire/fender contact point the junction where the rear bumper meets the rear quarter panel. Since that is closer to the 10 or 11 o'clock position of the rear tires, cambering them in another degree or so will only move the tire in a couple millimeters relative to this contact point. Hopefully that is enough.
Old 03-21-13, 07:10 AM
  #40
tgui
tgui's Avatar
Looks nice!
I still have a set of stock STi injectors and a stock TMIC if you're interested!
Old 03-21-13, 05:20 PM
  #41
VicTornin
VicTornin's Avatar
Thanks, will try the 255/35 and maybe 235/35 or 225/35 on front.
krdp2GS
09-09-15 07:19 PM
Caniac14
Build Threads
07-07-14 05:10 PM
FuMoFFuTT
SC- 1st Gen (1992-2000)
12
05-21-10 11:58 AM
broken_tsi
02-20-09 07:05 PM
specie
07-02-07 06:28 AM
Quick Reply: And the modding begins...
