Problem please helpppp (solved - cracked fuse)
hi my names ryan and i have a 2008 is-f. im new here and i am currently looking for some help with a problem. my car will not rev about 1500 rpms and the hazard exclimation mark symbol is blinking on my dash saying check vsc! i had a bad battery and thought with the little reasearch i have done that might be the problem but i put a new one in and the problem is still there. i own a scan tool so i scanned the cel and came up with code p2118 , it wasnt in my book of answers so thats why im here, all i can come up with is it has to be something with the throttle sensor or something. please help ive tryed pulling fuses and resetting the ecm but still no luck. i reset the cel with my little tool but it comes right back on as soon as its started. please help guys
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
maybe this thread will help. see post #3
https://www.clublexus.com/forums/is-...a-install.html
p2118 codes came up two of them p2118 and p2118p
Name of code:
Throttle Actuator Control Motor Current/Range Performance
Throttle Actuator Control Motor Current Range/ Performance
Name of code:
i checked all the fuses last night to and from what i seen they were all good. i will have to put a tester on them next to check for sure there good. i hope thats all it is......
you say your car is throwing a CEL, that would be the first thing i check
dont see how ur issue is a fuse related problem
Name of code:
Name of code:
Tech Info Resource
Just curious. What did you do to the car just before the problem?
Or did you just get in one day and have this issue?
all fixed!!! took a meter to all the fuses and one had a hairline break in it that was hard to see by eye. problem solved all is good thanks you guys!
I have the same code cuz I had a bad battery & my bro jumped started the car the wrong way
! Replaced the battery, but the P2118 is still there.
CEL on, VSC & trac control on as well. The car is on limp mode & look like it's starting on 2nd gear on Drive.
Can OP shares which fuse was cracked (and which box)? before I bring the car at the dealership on Tuesday! Thx
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
For future reference, our ETCS (throttle) fuse (#6) is located in the fuse box (#B) in the engine bay near the driver headlight (hidden under the plastic cover-panel). It's a 10A fuse. --> Look at the pic attached below.
Look under the fuse cover, it tells u exactly which fuse is the ETCS.. The good thing is Lexus even put spare fuse (# 1-2-3) in that same box.
![Name: photo_zps154050a0.jpg
Size: 54.7 KB](https://www.clublexus.com/forums/attachments/is-f-2008-2014/427618d1501330268-problem-please-helpppp-solved-cracked-fuse-photo_zps154050a0.jpg)
I am having the same problem, I am pretty sure it is because my boy jumped my car wrong... DONT TRY AND JUMP A CAR DRUNK. But these are the codes that came up when I took into the shop.. They said that it is a fuse and they cant order the fuse so I would have to take it to the Lexus dealership. Can I order the fuse and install it my self? and if so where can I order it from.
Tech Info Resource
