has anyone done this???
Old 01-09-13, 06:29 PM
KOKISF
KOKISF's Avatar
Default has anyone done this???
I was thinking of shortening the shifter shaft that holds the shift **** so is lower, cut a piece of the top and rethread the shaft with the proper thread . we used to do this on subarus back in the day abd it felt nice!!!
Old 01-09-13, 06:39 PM
darbs242
darbs242's Avatar
why? just keep screwing it down further. most of the after market ***** you can make touch the "carbon"
Old 01-09-13, 07:07 PM
KOKISF
KOKISF's Avatar
Because I want to keep the oem one !
Old 01-09-13, 08:25 PM
digger08
digger08's Avatar
Agreed I got my Fsport **** really low by just continuing to turn it.
Digger08
Old 01-09-13, 08:53 PM
ISFPOWER
ISFPOWER's Avatar
RCB helped me with instructions on lowering the oem shift ****.
looks great.
Old 01-09-13, 08:54 PM
1sWt2GS
1sWt2GS's Avatar
get another shift **** or keep screwing it down
Old 01-09-13, 09:40 PM
aWorkOfArt
aWorkOfArt's Avatar
Damn the stock shift **** looks good low! Gonna have to screw mine down when i get home. Thanks for the idea OP and for the how-to guys!
Old 01-09-13, 11:40 PM
MdLProd
MdLProd's Avatar
wow, I want to do this so bad? all you have to do is screw it further? no secret techniques required? haha
Old 01-10-13, 06:34 PM
KOKISF
KOKISF's Avatar
see all!!! good thread humm?
Old 01-10-13, 06:37 PM
KOKISF
KOKISF's Avatar
isf power did you cut and rethread or what, just screwit in?
does it work good
Old 01-10-13, 06:55 PM
ISFPOWER
ISFPOWER's Avatar
does it work good
i took the **** off, found a drill bit as wide as the shifter and drilled about half an inch then just screwed the **** back on. pretty easy.
it looks good in park but it does get longer again when you put it in D or M mode.
i was thinking of taking the whole assembly off , cut the shifter shorter and weld this to it and put an ARC Ti **** on it. i think it would look pretty sick.
Old 01-10-13, 07:27 PM
jbjones85
jbjones85's Avatar
I did this tonight and just for reference I used a 5/16th drill bit. As ISFPOWER said looks great in park but when in D it will look higher due to the arc that the shifter goes through. Still better than stock though for sure.
ISFTOMMY
IS F (2008-2014)
12
03-13-16 04:52 PM
zarraz
06-13-14 10:20 AM
configt
11-11-12 03:42 PM
JDMV8
IS F (2008-2014)
19
08-13-12 07:02 AM
RickJames1
03-03-10 12:53 AM
Quick Reply: has anyone done this???
