Apexi Smart Accel Throttle Controller Problem
Old 06-23-16, 11:43 AM
  #46
tas02
tas02's Avatar
There's always "Blue" mode for economy. Can't say I've ever used it.
And if you run at the drag strip, just turn it off. Otherwise, it starts flashing at the end of your run, and will require re-initialization to work correctly.
Old 06-23-16, 07:25 PM
  #47
MileHIFcar
MileHIFcar's Avatar
Originally Posted by IredSF
Oh about a whopping 12.3mpg!
Does this seem to be the consensus on the mpg to expect with this mod from owners who have this?
Old 06-24-16, 06:59 AM
  #48
s4chico
s4chico's Avatar
Why would it have to be re-initialized? How is the drag strip different from 'spirited' driving on the street?
Old 06-24-16, 12:44 PM
  #49
ModInJapan
Lexus Enthusiasts
ModInJapan's Avatar
That white blinking mode is when its first installed and isnt calibrated yet, not sure why it went back into that mode but thats just the default state.
Old 06-25-16, 01:53 AM
  #50
Tokenblkgy
Tokenblkgy's Avatar
Jesus I still need to install mine I purchased in March lol
Old 06-25-16, 08:55 AM
  #51
5280ISF
5280ISF's Avatar
I get 17 mpg or thereabouts around town... My foot is usually in the throttle pretty good. I run red mode and sport most often. I tried purple and sport the other day... Think I still prefer red and sport.
Old 06-25-16, 08:58 AM
  #52
5280ISF
5280ISF's Avatar
You should do it today....takes less than 30 minutes and provides a felt improvement in throttle response that sets you back in the seat nicely.
Old 06-26-16, 03:31 AM
  #53
ISF5L
ISF5L's Avatar
Like a few others i feel purple hits harder and is more extreme but if you use the paddles a bit and drive it manually red is much better regarding throttle.
Old 06-27-16, 07:54 PM
  #54
IredSF
IredSF's Avatar
Old 06-27-16, 08:07 PM
  #55
tas02
tas02's Avatar
Originally posted by s4chico:
"Why would it have to be reinitialized (if turned "on" at the drag strip)?..."
I can't explain why. It just does.
Old 06-27-16, 08:12 PM
  #56
MileHIFcar
MileHIFcar's Avatar
That's sweet! To drop 5 gears on demand
Old 06-28-16, 10:54 AM
  #57
Durrby
Durrby's Avatar
I installed the throttle controller a few months ago and have only used the red mode. After reading this thread I tried using the purple mode. Question, is it normal for the unit to flash for a few seconds when you hit the gas peddle? I went through all the modes and it only stays solid on red and green mode when hitting the throttle. In all other modes when you even slightly touch the peddle the unit flashes for a few seconds. I assumed I went through the calibration steps correctly as the unit seemed to work fine in red mode.
Old 06-28-16, 12:23 PM
  #58
Quadrphnia
Quadrphnia's Avatar
Went with purple for a bit and I have a concern about the amount of down shifting. Seems that the curve makes the car downshift CONSTANTLY without or without traffic. Not crazy about this extra toll on the trans so I'll be going back to red.
Old 06-28-16, 02:42 PM
  #59
IredSF
IredSF's Avatar
Mine flashes in all colors when it's working and this is after calibration (if throttle is in it flashes)
Old 06-28-16, 11:48 PM
  #60
Durrby
Durrby's Avatar
Hmm wonder why it doesn't do it in red/green mode then.
Quick Reply: Apexi Smart Accel Throttle Controller Problem
