Dipstick leaking at engine block
I installed Sikky headers about six months ago to find out that there is a very slow leak. hus, I called Sikky and they helped me very quickly and sent out a new oring im hoping will be the fix. Those of you who have personally installed their headers how difficult once I drain the oil is it to actually remove the dipstick tube form the block and replace the o-ring; or anyone whohs any knowledge for this task. Anyone else experiance such problems. Input is grealy valued .
from seeing my friend install two sets of sikky headers...the dip stick is a pain in the a**. one of the F's was also leaking oil from the same spot you mentioned. my friend would have the top lined up where the bolt and bracket is but the bottom end was off. alot of bending and tweaking had to be done to get it to fit correctly. now with you already having the dip stick installed...it shouldnt be too hard to remove and replace the oring but the reason i believe it is leaking is because the dip stick is not bent correctly..if that makes sense. good luck and let us know if you had success.
Yea what David said. I had a leak due to the dipstick o-ring as well. The mechanic installed the oem o-ring no problem. The sikky dipstick is a pain to install and is not bent properly especially where the o-ring meets the dipstick.
from seeing my friend install two sets of sikky headers...the dip stick is a pain in the a**. one of the F's was also leaking oil from the same spot you mentioned. my friend would have the top lined up where the bolt and bracket is but the bottom end was off. alot of bending and tweaking had to be done to get it to fit correctly. now with you already having the dip stick installed...it shouldnt be too hard to remove and replace the oring but the reason i believe it is leaking is because the dip stick is not bent correctly..if that makes sense. good luck and let us know if you had success. ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
I installed Sikky headers about six months ago to find out that there is a very slow leak. hus, I called Sikky and they helped me very quickly and sent out a new oring im hoping will be the fix. Those of you who have personally installed their headers how difficult once I drain the oil is it to actually remove the dipstick tube form the block and replace the o-ring; or anyone whohs any knowledge for this task. Anyone else experiance such problems. Input is grealy valued . ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Hey StealthFF,
I was reading through your thread and I just wanted to drop in and give you some advice for this dipstick tube. Usually if you are having leaking issues its because the o-ring isn't seating properly. You'll have to be very careful when installing it so it doesn't pop out of the groove. Putting some lube on it definitely helps too, that reduces the resistance. We've changed our manufacturing process of the o-ring groove to help minimize the o-ring popping out but it does still happen sometimes. Feel free to give us a ring, 410-780-0009, if you encounter any issues and we'll be glad to help you out. Thanks!
-Justin
Sikky MFG
Yo shaun, if you need some help with the work lmk. I can tell cam to help you out. I went with them oem dipstick for the same reason that it wasnt bent right. Lmk if you need help homie
hanks for the input Sikky and guys...yeah I will definately hit you up Elmer once I finish this automation job at work andget back in twon I want to come see your beast anyway!! thanks for the offer of assistance!
I don't know what updates Sikky did for their dipstick/o-ring, but the OEM dipstick and o-ring does work to solve the problem. You have to bend it yourself to get it to fit, but it works. Good luck!
