Brake dust on my wheels!!!
Old 01-27-13, 10:56 AM
KOKISF
KOKISF's Avatar
Default Brake dust on my wheels!!!
The brake dust on my wheels is very hard to remove what are you guys using for this is insane and the brakes are oem so as the pads!!!
Old 01-27-13, 11:00 AM
zapa
zapa's Avatar
p21s gel formula let it sit for two hours and wash off. You may have to do a tiny bit of scrubbing but it works the best.
Old 01-27-13, 11:32 AM
thatnewguy
thatnewguy's Avatar
I've been wondering the same, haven't seen any issues elsewhere, but I figured it was only a matter of time
Old 01-27-13, 11:47 AM
fasttexasz
fasttexasz's Avatar
IronX is the only thing that has really impressed me. They have a gel and a spray and it changes colors to let you know it's doing its job. I usually do my wheels at least once a month just to get out the corners of my where's where the dust naturally settles. It's also safe for painted surfaces so after a road trip I'll hit up the fenders to see all the iron from the brakes go away to avoid pitting the paint. Ironx is a neutral unlike a lot of other acid based products that are out there. Only problem is you can't usually find it locally but there are plenty of places online such as autogeek. Good luck!
Old 01-27-13, 11:52 AM
Mrd916
Mrd916's Avatar
I changed my pads out to aftermarket ceramic pads and it's like night and day difference in brake dust. Now all I use is soap and water once a week and wheels are like new. I used to use Sonax on my wheels when I had factory pads and it worked great but would be covered in dust a couple days later.
Old 01-27-13, 12:10 PM
Just F Me
Just F Me's Avatar
soap, water, microfiber, and put your back into it.
Old 01-27-13, 12:20 PM
flowrider
flowrider's Avatar
Received 1,949 Likes on 1,372 Posts
Look Here:
https://www.clublexus.com/forums/is-...rake-dust.html
https://www.clublexus.com/forums/is-...ng-battle.html
Lou
Old 01-27-13, 02:15 PM
zapa
zapa's Avatar
please dont tell me you wasted you 1500 post saying that. Also that method is what I go with once i run out of wheel cleaner.
Old 01-27-13, 02:25 PM
avgj0F
avgj0F's Avatar
YGBSM!
Small amount of inexpensive soap, various sponges sizes and 30 min, including cleaning between the nuts, shiny black caliper and the back side of each wheel spoke. Optimum Opti-Seal once a month would help too.
Old 01-27-13, 02:57 PM
BULLIT
BULLIT's Avatar
After cleaning them you should coat them with CQuartz or nanolex alloy wheel protector. It makes cleaning them a lot easier.
Old 01-27-13, 03:05 PM
2URGSE
2URGSE's Avatar
2 hours is a little excessive IMO.
OP, you would also want to get a special teflon brush for wheels and scrub them after spraying the P21S and then hose them off.
I personally take off the wheels off the car once a year and clean them by hand, then seal them.
Letting the brake dust sit there and cake on the wheels will damage the finish, and putting ceramic pads will cut on the braking performance.
Old 01-27-13, 03:16 PM
bnizzle87
bnizzle87's Avatar
Sonax Wheel Cleaner is what I've been using, and it certainly does the trick. Sprays on green and turns purple when the grime has been penetrated. Safe on all wheel types. I've always recommended it to friends, and they've had nothing but great praise for this product. I'm more than certain a few vendors here sells it on their sites.
Old 01-27-13, 04:24 PM
KOKISF
KOKISF's Avatar
I never heard of those products before !!!
Old 01-27-13, 04:32 PM
BULLIT
BULLIT's Avatar
nanolex
http://www.nanolex.de/en/products/na...-alloy-sealant
IronX - be warned this stuff stinks but is amazing
http://www.cquartz.com/pages.php?page_id=89
CQuartz
http://www.cquartz.com/pages.php?page_id=69
Old 01-27-13, 04:41 PM
streetx
streetx's Avatar
This, i wont use anything else but Sonax
http://detailersdomain.com/Sonax-Ful...0ml_p_324.html
Quick Reply: Brake dust on my wheels!!!
