Mr.Slay's Teaser Thread
Old 03-11-13, 03:18 PM
  #91
MRxSLAYx
MRxSLAYx's Avatar
3.11.13 update in post #2
https://www.clublexus.com/forums/7750076-post2.html
Old 03-11-13, 05:29 PM
  #92
CCJ22
CCJ22's Avatar
Originally Posted by MRxSLAYx
That is not the update I wanted to read.
Old 03-12-13, 08:47 AM
  #93
CarbonISF
CarbonISF's Avatar
Turbo won't work even with sard tuning?
I'd be really excited to see what kind of power you can make with a full built NA motor and a good tune! This is even more appealing to me than turbos, and a lot easier to explain to the insurance company if the need ever arises... I love my F as a DD.
Old 03-12-13, 10:51 AM
  #94
Lexura1414
Lexura1414's Avatar
I agree with carbon. NA is more exciting to me..
Old 03-12-13, 10:59 AM
  #95
vbb
vbb's Avatar
I agree with both of these guys. I'm even more excited to see what you can extract out of this engine from an NA standpoint than I was to see some frankensteined turbo setup with questionable reliability and tuning options. Good luck and keep us updated!
Old 03-12-13, 11:01 AM
  #96
cremaster
cremaster's Avatar
still interested w/ your build, man. keep us posted!
Old 03-12-13, 11:12 AM
  #97
ShadowISF
ShadowISF's Avatar
Yeah, I love NA cars, but this project is awesome!
Old 03-13-13, 12:30 PM
  #98
madastep
madastep's Avatar
You just getting it ready for more spray?
Old 03-14-13, 05:10 AM
  #99
MRxSLAYx
MRxSLAYx's Avatar
Thanks for all the continued support guys.
The motor will be able to handle a ridiculously large shot... If I can find a way to get around the timing. We have developed a way to put a standalone on the car, but it requires a good amount of sacrifices that would force my hand into the big power turbo setup. As of now, the car is going to need a really trick set of headers to handle more nitrous as the Sikky Headers are beyond there limits at 550whp on nitrous. Ill post a pic blow and try to explain why...
Ok. So I couldn't find a good picture so this one will have to do. Looking at the exhaust ports with the head off the car, we noticed that the buildup was progressively worse from the back of the motor to the front. The builder had never seen a set of headers on the motor, but was amazingly able to describe how they looked just based on the buildup that was left on the head. Taking a look at the design of the headers, you'll see that they begin to bend aggressively very shortly off the head. This causes a restriction in flow and increases the pressure on the exhaust side, which is apparently a very bad thing. Because of this discovery, I am most likely going to have a custom set made that will be nitrous friendly.
Old 03-14-13, 05:19 AM
  #100
melbitoast
melbitoast's Avatar
Good luck, Slay. We're all rooting for you.
Old 03-14-13, 06:59 AM
  #101
streetx
streetx's Avatar
good luck with your build
never thought about that bends on the header until you mentioned it
Sikky
PPE
Hard to tell but looks like PPE is a little less agressive with the bend
Novel
Old 03-14-13, 09:22 AM
  #102
Vroomin350
Vroomin350's Avatar
Wait, are you still using the 2J platform or turned over to tuning the GR?
Old 03-17-13, 10:04 AM
  #103
LexF
LexF's Avatar
So based on this, PPE > sikky?
Old 03-17-13, 10:20 AM
  #104
MRxSLAYx
MRxSLAYx's Avatar
No definitely not. PPE has the same problem on cylinders 1-4. Due to the space constraints, it may be best to use larger diameter piping. Ill let everyone know how we move around the problem when we get there.
2JZ in the ISF was a backup plan of a backup plan. The 2UR has been the build of choice from the beginning.
Old 03-17-13, 01:25 PM
  #105
rw95gt
rw95gt's Avatar
I was thinking they prob had no choice but to have the aggressive bends on a few cylinders with the space available. Also the stock manifolds are terrible with the aggressive turn on all 8 cylinders. Most are basically 90 degree turns. Sikky and PPE are both way better over stock. But I understand for your build needing larger headers. The only thing is how can they be ran without bending so hard? I haven't been fallowing your car stuff much lately. Did you hurt the stock engine?
The Novel headers are equal length correct?
Quick Reply: Mr.Slay's Teaser Thread
