What if I just took the resonator out?
Old 02-08-13, 06:42 AM
2012ISF
2012ISF's Avatar
Will i lose back pressure and be slower!!!
Old 02-08-13, 08:13 AM
VtotheJ
VtotheJ's Avatar
No mufflers/cats = less restriction = more air flow = less back pressure
No mufflers/cats = weight reduction = faster
Old 02-08-13, 09:29 AM
vmatheboss
vmatheboss's Avatar
so are you only running the straight pipe to one of the muffler tips? the other one is just empty behind there?
Old 02-08-13, 03:48 PM
VtotheJ
VtotheJ's Avatar
Yes, but you can barely see it. As you know the muffler tips aren't connected to the exhaust but on cold start you can see the smoke coming from the tips because the pipes sit right behind them.
Old 02-09-13, 07:01 AM
Gearbangin
Gearbangin's Avatar
Originally Posted by VtotheJ
Clips are on youtube... I'll try to take one tonight before we get that blizzard tomorrow. Most of my clips are on my channel http://www.youtube.com/user/remiks3/videos but they are all me either revving or at WOT.
Best way to describe it is, at 2k RPM it's loud but tolerable at other RPM's. the sound intensity varies. If you're cruising on the hwy on level ground and you lightly rest your foot on the pedal, the car pretty much sounds stock.
Heard those sounds sick. Im looking for interior window up start, cruise, full throttle etc.
Old 02-09-13, 08:51 AM
vmatheboss
vmatheboss's Avatar
ah ok. yea i see the smoke on the cold start for sure. i got guys that for some reason always look at the tips and say, "wow you got 4!" then they start looking into it to make sure its not only a cosmetic thing where theres only 2 tips but split into 4 lol.
is there another way to cut it rather then removing the muffler part and still gain similar sounds?.
Old 02-09-13, 02:02 PM
VtotheJ
VtotheJ's Avatar
You could probably keep the mufflers and remove the resonator and secondary cats...that might work. But I've heard it sounds the best when the mufflers are removed.
Old 02-10-13, 03:39 AM
AussieISF
AussieISF's Avatar
That 2k RPM drone is bloody annoying. I've got a Borla catback myself, after adding 2 venturis and applying dynamat behind the rear seats, it's helped a lot but not completely eliminated it. Is there an aftermarket system out there that doesn't have the dreaded 2k drone? I'm quite sensitive to the sound.
Old 02-10-13, 05:13 AM
jkeifer3
jkeifer3's Avatar
Interesting you should mention this. On one of my Corvettes, the 1999, I installed a high flow exhaust system and actually lost some power. I could only tell by the seat-of-the-pants feeling because I didn't put the car on a dyno or anything. Still, the effect was noticeable.
So, from what I have experienced, a loss of some back puressure can indeed lead to less power.
Old 02-10-13, 05:30 AM
caymandive
11 Second Club
caymandive's Avatar
The F will gain some power no matter what you do with the exhaust. There are gains from removing mufflers, secondary cats and primary cats. Obviously the best approach and one that will yield even more power for those budget minded is to just get a Borla true dual system that can be had for under $1000 new and even better deals on used.
Hacking the OEM exhaust has its expense and downfalls.
Old 02-10-13, 07:18 PM
VtotheJ
VtotheJ's Avatar
Here's a clip for Gearbangin and other skeptics
Various in-car noises of the exhaust mod......I tried covering all of them. Hope this helps those that want to do the same thing.
Old 02-10-13, 07:41 PM
vmatheboss
vmatheboss's Avatar
thanks. im still debating...might go towards borla lol
Old 02-11-13, 12:27 PM
Gearbangin
Gearbangin's Avatar
Wow sounds good not too loud at start up and cruise. Decisions Decisions. You may have just saved me a 1,000. Thanks again!!
Old 02-11-13, 02:55 PM
Damage
Damage's Avatar
Curious, but how come I don't hear anyone using electric exhaust cutouts?
Old 02-11-13, 03:30 PM
VtotheJ
VtotheJ's Avatar
People have before and the electric motors just burn out
Quick Reply: What if I just took the resonator out?
