Help: Dome, and interior lights not working
hey gents,
The interior and the front and rear dome lights in my F don't seem to be working. However all of my interior buttons are lit, and my gauges seem to be working fine (minus the gas gauge taking its time to show changes after a fill up recently)
I have checked the manual for the potential fuses, but none of them are specific to the problem.
Can anyone point me towards the correct fuse/relay before I go and check every fuse individually?
Thanks in advance.
Thanks in advance.
i do not know the exact cause of the problem, but i had a same issue and took my car to the dealership since it was under warranty. none of the dome lights was working (including doors), and the gas gauge not responding right after a fill up. read the service description, and all it mentioned was reconnecting loose wires. yours is 2010, should be covered under warranty..
Found the issue!
It was the fuse I thought it would be, but one of the last that I checked (not sure where my logical thinking went on that one)
Fuse #9 in compartment A- DOME 10A
Interior lights, meters, and gauges..... Funny as all gauges , minus the fuel gauge, were running as per usual.
Thanks for the help, hopefully this helps someone out in the future.
rwheelz
07-15-15 11:43 AM
