Where can I get an exhaust flange?
Does anyone know where I can get the exhaust flange from the axle back portion? I was at a buddies fab shop and he wants to build me a axle back, however the flange from that point is very odd. he literally had 40 to 50 diff flanges but the Lexus one is an odd shape.
any help would be appreciated.
^^^^That's a 2.5" flange. Lexus describes the stock exhaust system:
2.5" won't fit properly on a 2.7" pipe.
Lou
The stainless steel exhaust system starts with tubular exhaust manifolds and integrated catalysts. Next come dual 2.4-inch diameter front pipes that are joined before a pre-muffler and 2.7-inch single center pipe, after which the system splits into two 2.1-inch pipes and enters dual 16.8-liter mufflers.
Lou
The Maker
I made some back when I was developing my ti axle back. Still have 5 left SUS 303 its 100mm
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
that Megan flange sure looks correct. I found 1 on ebay that is identical. does it matter if the piping is different as long as the flange connects correctley. the muffler shop can use 2.5 in pipes?
The Maker
I can pretty well assure you if they are listing it as a universal part and its showing for the 350 and 250 then its not. That is why I designed my own.
__________________
The Maker
I also have the bolt on flange laser cut out of stainless so its a compression fit. So its a 2 piece flange. This is just what I had a picture of readily.
__________________
carid
Club Lexus Vendor Marketplace
06-24-16 03:45 AM
JAndersson
27
02-24-14 01:05 AM
