Right. I agree. There are several write ups on several sub forums describing the process of pumping a couple of quarts out and then a couple in so the pump stays supplied. This process isn’t a secret on any CL board and I was not advocating “running the pump dry.”
Do yourself a favor and build this. A 10 dollar spray pump and some 3 dollar hose. Works like a charm. I put in roughly a quart, and I’d guess I got half of it back or a little more.
For the ultimate in simplicity, bend a piece of copper tubing into a truncated J so you can hang the hose on the side of the transmission. I do the gravity thing with patience. I'm not a fan of pressurizing fluids directly with air if I can avoid it. The air tends to dissolve in the fluid, and that's never preferred.
First time ever posting: my F started to have flares/slips at 75K and my service manager at Nalley Lexus stated as most of know the transmission is sealed and "not serviceable": will have words for him if I ever take it back there. Researching Aisin they recommend a full flush at 60K (as a number of people have stated). My local Toyota dealer has the machine to properly flush/fill the transmission with WS for $299; I think money well spent for the 1.5 hour wait/service time, knowing the fluid level is correct, and not having to deal with the 11 qts of waste. Completely resolved the flaring/slippage issue I was having; which led to an awesome track day at AMP last friday.
I live 5 minutes from a county recycling facility, so I couldn't care less about haz waste. I take it there and give it to them routinely and it costs me nothing but the drive.
Wanted to get more opinions from you guys as I've already asked illwillem on IG. So I've been having this issue since my last two track days and no issues on the streets. Seems like it's low on transmission fluid? I've already replaced the belt and tensioner about 1-2k miles ago. It's more prevalent from 3rd to 4th on the straight and can be random too on some corners. I already went to Lexus today for a drain and fill in which they were hesitant due to the risks once the fluid are changed. They're waiting for the gasket to come in and I've also asked for a new filter to be ordered.
Changing trans fluid should be a cake walk for any dealership. Easy money. I don’t get their hesitation. It makes me question if the dealership has a decent mechanic in it.
The "head parts guy" at my local toyota dealership told my brother a 07 Tundra didn't have transmission filter/strainer. I called him back with the part number and asked if he had it in stock, didnt say a word other than no.
What that really says is they never service the transmission on a Tundra. Parts in stock are parts that move quickly. If you have to order it, they're not selling. I once had a problem with a Camry 2.4 liter's EGR. The diagnostics said the EGR valve was bad. I was at the parts counter, ordering a new EGR valve and a good friend who happened to be a service manager asked me what I was doing. When I told him, he said, no that's not the problem. The problem is the VSV that controls the valve. I am sure it's in stock, they go bad all the time. Sure enough, it was bad AND it was in stock. His advice - check which parts are in stock before ordering anything on a widely popular platform. Odds are good the part in stock is the problem, not the part you're ordering. This has served me well for over 20 years.
my issue was that he claimed the tundra didn't have one, as in, they manufactured it with out one.
So, I won't say my gearbox turned foul on me because it has not. I will say after completing the level check today, I think checking the level and the oil quality are mandatory.
Symptoms - after a hard left hand turn on the gas hard, transmission failed to upshift. Completely failed. Had to put it in manual and shift up, then normal operation resumed. Unsure if this actually causes damage internally since the TCU decided there was a good reason to hold in gear.
Solution: Level check and add fluid.
The level check is a PITA. I have Techstream on my laptop to make it a little easier, but the first time doing anything like this is always fraught with peril.
Step 1 - put the car up on four jackstands because I don't have a lift. Remove the undercover from the gearbox to expose the fill check plug on the oil pan.
Step 2 - Level the pan on the gearbox by adjusting the jackstands - my garage floor isn't perfectly level, but the oil pan on the gearbox was when I had the stands one click more in the front than the back.
Step 3 - Connect to the car with Techstream and check the ATF temperature. Crap. 126 degrees even after sitting for 5 hours. Wait until tomorrow to start.
Step 4 - Check ATF temperature with Techstream connected again the next day. 89F after sitting all night. WTF? It's 79 degrees this morning???
Step 5 - Start the engine, follow the procedure - row the shifter from P to M and back slowly, then move it to D, then back and forth between D and N until the N disappears for 4 seconds. Return shifter to P. Check temperature. Display is blank. When the temperature reaches 95F, the P reappears on the Multidisplay. Time to remove the fill check plug from the oil pan on the gearbox while the engine is idling. See absolutely nothing but a few tiny drops come out. OK, definitely need more fluid. Remembering yesterday's wait for the temperature to drop, and knowing if I let the car run the temperature will rise, shut off engine quickly.
OOPS. Now I have a small lake of ATF forming underneath the car. Apparently, the level drops with the engine idling, and as the fluid drains back into the pan when you shut the engine off, ATF comes out the fill check hole. Suck. Stuff the plug back in the hole and snug it finger tight. Clean up the big oily mess because my drain pan was off a couple of inches. Get the prepaid sample bottle from Blackstone, remove plug briefly again to fill a 2 ounce sample, then plug the leak again.
Step 6 - Wait for exhaust system to cool a little. Wait some more. Find out the primary cat stays dangerously hot when the piping is cool to the touch. Wait some more...Finally, get to the 24mm fill port bolt up high on the side of the transmission. Lexus recommends an SST for this. I recommend a very shallow 24mm socket and a thin breaker bar - it's not super tight, but the space is very limited. I was just able to squeeze a standard height socket on a 1/2" breaker bar onto the nut to crack it loose, then had to remove the socket and finish with an open end wrench. You could also take a standard socket and cut it down to give yourself some room to work. Be creative and inventive to figure out how to get ATF from conventional 1 quart plastic bottles up to the fill port. I used a hard plastic line I normally use for differential fills and got it stuffed in the fill port, then ran it out to a funnel on the driver's side where I was able to pour in ATF. Worked just fine, except the line had a spot lower than the fill port, so some fluid remained in the line from gravity. Luckily, I was able to use a small shot of air from my compressor to clear the line completely. I added 1.5 quarts thinking I needed to ensure I made up for my losses (also meaning I was swapping out a tiny volume of ATF).
Step 7 - repeat temperature and fill check plug drill. Small dribble out of the fill check port. Crap. Should have poured the whole 2 quarts. Reinstall plug in fill check port, shut off car, run through step 6 again adding the remaining 1/2 quart from the second bottle, PRAY to the automotive gods for the temperature to be within limits (95F t0 104F).
Step 8 - Prove you learned something valuable in step 5, and run through the whole procedure again to check the level. This time, ATF comes gushing out of the fill check port (success!) and quickly slows to a steady drip. Stuff the plug in the hole, tighten to a reasonable torque because 15 ft-lbs in the manual is making the 5mm hex bind in the bolt head.
So, after all this I button up the bottom, get the car off the stands, and take it out for a test drive. No shift hang on a left turn while accelerating hard. In fact, none of the usual symptoms I had become to expect as normal - driving down my driveway to the bottom of my street, no issues with holding gear or accelerating normally where it used to feel as if the transmission was either flaring or slipping. Only on cold cycle, and only after downhill without warming, but definitely annoying. Also noticed a noise I have become to expect to be normal - sounds like a an old hydraulic power steering pump just beginning to groan - disappeared.
So, despite Lexus firm recommendation to only check for leaks, I really think the level needs to be checked and reset routinely as well. I had long suspected I had low fluid, but I've been putting off doing anything about it while I waited for the 120,000 mile mark to send in my second ATF sample to Blackstone. I won't go so far as to say, figure out how to do an oil change (but I am fully expecting Blackstone will tell me the fluid is either dead or only has a few gasps left before necrosis sets in. I bought a case of WS just for that reason, and I have some ideas how I might perform this if it is true. I won't be using the oil cooler lines, I have a different idea. I'll post more about it when it truly becomes necessary, and hopefully it will be DIY friendly for those who know the difference between a #1 and a #2 phillips.
Blackstone sample sent off today. Should have results in about 10 days or so. I'll post them here.
It's really nice to have it shifting like new again...
thanks for the information
what would be the best way to do a quick fluid check and see if it’s overfilled or low on fluid?
I can now attest to the fluid top up process. Just got my car back from the dealership a few days ago because the car has actually been having the random "shfit flaring" aka low fluid symptoms for quite some time now. Had them do new filter, seal, and correct fluid level and wow I can legit say the car shifts noticeably different now, a lot more crisp/precise because it felt almost lazy sometimes.
2008 w/ 176k miles, never touched the trans in my 7 years of ownership but I see it made a world of difference with the correct fluid level
Same when I had a new transmission filter/seal replaced a couple months ago along with the new fluid and top off my transmission got rid of it's flare it had developed because of a low level and now shifts sooo much better!! The AA80E is a finicky transmission when it comes to fluid levels and shift behavior.
Below is an article I ran across I found interesting:
This thread really needs to get all the information condensed into 1 post . Just spent 1 hour listing through it and still don't know how many oil I need to buy.
I see in post #99 it mentiones 3.7L for oil pan removal, 4,7L for valve body removal and 6.7L for Torque converter so 15.1L in total? Then I see someone mentiones 11L in some other posts, others mention 6quarts (5.5L)....
So can someone clarify how many oil is needed for full flush and how to flush all of the oil out?
I had radiator blow up 3 months ago at 110 000km so while doing the radiator I replaced 4L of oil through oil cooler (drained about 3.9L, poured in 4L can, don't have any shifting issues).
Oil coming out was quite dark.
Now I want to do full flush and replace the filter so how much oil do I need to buy? I would really like to buy as close as possible to what I need.
If there is no simple way of draining all the fluid out, what is the next best method to get most of it out? I know there is always going to be some left in torque converter.
Also, is the oil strainer discontinued or something? I see it's out of stock at all usual suppliers here in Japan and I've noticed few people started selling them around on online markets at 3x the price and that's usually the indicator of parts being discontinued.
