Hood lift support struts..blew out
#31
Is it 'LiftSupportDepot'? I can't find a seller with the exact name:
http://www.ebay.com/itm/Qty-2-IS250-...MAAOSwB09YR5SR
http://www.ebay.com/itm/Qty-2-Lexus-...IAAOSwJ7RYR5fA
#32
Tech Info Resource
Yes, that's the guy. I didn't order the Sachs units, but if you search you'll see he has three options for 2IS. Don't worry about it being IS F specific, any 2IS strut will work fine. I got mine in 2 days for both fronts and rears. They work perfectly, and I got both ends of the car done for less than a single unit from Lexus.
This is what I bought for the hood. It's cheaper now than when I bought it.
http://www.ebay.com/itm/Qty-2-StrongArm-6797-Front-Hood-Lift-Supports-Struts-Lexus-06-15-IS250-IS350/332009701093
This is what I bought for the trunk - it's more expensive now than when I bought it:
http://www.ebay.com/itm/Qty-2-IS250-...-/331850216371
I also bought new hatch struts for the wife's Scion from them. All have fit and performed flawlessly.
The following 3 users liked this post by lobuxracer:
#34
Tech Info Resource
I originally paid $44 for both fronts and rears. Apparently the rears have gone up in price. There are cheaper vendors on eBay, I can only vouch for the one I used.
#35
Liftsupportdepot is great. I have replaced both my hood and trunk struts using them. Fast shipping and they work great. They have their own we site as well as the ebay store.
#39
Finally replaced mine. The cold weather snap killed my hood support struts.
$30 per set, not bad at all, let’s see how long it lasts.
#40
How have they performed so far? I need to buy new ones for my hood and trunk as well. Dealer quoted me like $184 a piece. Definitely going to pass on that.
#41
Tech Info Resource
Still working just fine. The one in the trunk did decide to pop off at the far end one time, but I might have been a little sloppy on the install, or bumped it with something large in the trunk. Not sure. Hooked it back up and it works perfectly still.
#42
Hey thanks for the insight brother. I just ordered the same ones you bought and want to give them a try. I can't believe the dealer wanted like $184 per strut. If I had them order and install both for the hood and trunk, it would of been like $800 alone.
#43
I also have to do mine, I paid a little more for the Sachs, but I doubt theyre any better.
For removing the old ones - is there any trick ie a tab or anything, or do you just pull them off?
Thanks
-R
Thanks
-R
#44
As far as I know they are like any hood/trunk dampers. There is a clip where they mount and I usually just use a flat head to lift it out of place. Once it's removed then the damper can be removed freely. Just be sure to secure the hood with something because it is heavy. Same for the trunk.
#45
Tech Info Resource
