1st free oil change at dealer?
send my is f to the dealership for the first oil change. is it worth it or should i just do it myself..
if its best to send in. should i have them do the lexus personalized setting. if so what option should i get. i rember my old is350 i can roll down all the windows just by holding the unlock button. i miss that option. any input will be greatly appreciated,
.....and be prepared to spend a little more on oil changes in the future
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Windows - You should be able to preform this function now...the only option on the programming was to have the sun roof open at the same time or not....I guess yours is turned off?
Digger08
so got my car back and couldn't be happier. but i notice on the invoice... the tec used synthetic toyota oil 0w20. dont we need 5w30? the
oil filter is a 90915 - yzzd3, check sewells and appears to be different.. should i be concerned ?
hey jeff thanks for the response. wondering f this has been ask before. is there any diff between the two filters
1.04152-51010 is the IS F filter - This is the one from dealership.
2.(04152-YZZA4 can be used in a pinch - this is the filter that sewell sells. for the is f.
i talk about it here in the 350 forum as well
https://www.clublexus.com/forums/is-...ml#post7884513
i apologize if this has been ask before. i did a search and came up with nada.
sewells claims in a email sent to me that a4 can also be used for the is f safely.
found my ans here if any one needs. seems like its been debated alrdy.
https://www.clublexus.com/forums/is-...-filter-5.html
so the dealer put in the wrong oil. also noticed some oil leaking around the filter housing. its not dripping or anything but i can see a ring of oil forming around it. should i take care of it now. basically do the oil change myself. or just take it back. seems like every time i go to the dealer .. they fix one problem but make another problem.
for instance 1st time i went for oil change, they put in the wrong oil. 0w20. 2nd time i go they used everything correctly but now i have oil leaking from my filter housing.
is that normal for the is f?
yea i read my manual it says to run thicker for hard use. x w40 not the other way. lexus of Westminster usually treats me right wonder if the tech work on is f?
i checked under my car today . and it still leaking some oil . wonder if they even put in a o ring.
Tech Info Resource
What manual says run thicker oil? Nothing in Lexus documentation says this. If this is a Haynes manual, they really don't know what they're talking about and I would not follow a recommendation like this when the exhaust cam timing is controlled by oil pressure.
This is what the US owner's manual says - there are no 40 weight options at all:
