headlight keeps going out
i have a 08 isf and my driver side headlight keeps going out , i have got it "fixed" to many times to count and it will work for abit then go out while driving
how do i fix this i have changed the ballists numerous times swell
Swap the bulb from passenger to the driver side and see if it does the same thing. if it does, then you may have a problem on that headlight. I had the same problem before. i had to take it to my dealership have them put a new ballast and bulb and it still didn't work. i ended up buying the entire headlight assembly on the driver side. I had moisture going in it so that probably had something to do with it. Use process of elimination.
Jaybeck860
IS - 1st Gen (2001-2005)
01-27-14 11:08 PM
