Question about tire sizes for 19" wheels
Hi all,
I saw some posts about some of you running 245/35 and 275/30 tires setup on stock wheels, and I was wondering if I can run 245/40 and 275/35 on 19" wheels instead??![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
The reason I want the taller sidewall is because the roads where I have to drive are horrible and I could use the extra 1/2 inch to cushion the ride. My main concern is rubbing against the lining up front ESPECIALLY when turning (not sure about the rear either). I'm sitting on coilovers and I have camber kits both up front and back, so I can adjust the ride as needed to avoid any rubbing at the 12 o'clock position.
245/35 and 275/30 are shorter than OEM tires and have a slimmer sidewalls. I need to order the wheels this week because I'm still running winter tires and it's 70 degrees outside!
and if you're curious, I'm looking to get Continental DWs ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
Thanks!
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
Thanks!
See response from another thread that is similar to the question you are asking
Quote:
Originally Posted by tybg
hey guys, quick question. ordered some 245/35 front and 275/35 rear pss from tire rack but running into this thread made me do some searching and it seems EVERYONE is running 275+/30 in the rear. is there a reason for that? will the sizes i ordered cause any issues? i still might have time to change my order, please let me know my is-f brethren
The stock tire has an OD of 26", the 275/3019 is 25.6" and the 275/35/19 is 26.6" in diameter. The front 245/35/19 is 25.8" in OD. Lexus has designed the ISF to maintain tire height equality between the front and rear. You may or may not notice a difference with the taller tire, but if it were me, and it was, I would keep the ODs the same or very close to equality as I could.
Lou
Lou
Thanks! actually 245/40 and 275/35 have similar diameters, 26.7" and 26.6" respectively, so there shouldn't be an issue with maintaining tire height equality between the front and rear... the odometer will be registering slower speeds than actual, but other than that (and possibly rubbing) I don't know what issues are there with running this setup.
What are the issues if there's a discrepancy, say 245/40/19 in the rear and 225/40/19 in the front on a stock setup? (in other words, the rears are slightly taller than stock)
Tech Info Resource
avinad
09-05-15 09:12 AM
