accelerating from deadstop
My F seems to be more tail happy lately, or maybe it was always like that from the beginning...
So my concern is, I'm at a complete stop and I want to open up the car till top of 2nd gear; when I put the pedal to the floor, the tailend would start going one way, usually slight left, and I have to countersteer to keep the car straight. And this is all when the day is clear, temperature in the 20s. All driving aids are on, no sport mode or M-mode on the gears.
Is this normal? or just the nature of the beast?
I've gone to the strip last year, and best I could pull was 13.5 @109. And I also had to fight a little off the line to keep car straight as well.
And this only happens when I take off, doesn't pull to either side in-between shifts.
It is normal....You have 2008.
You need to instal LSD to achieve both wheels take off without needing to counter steer.
Search for limited slip differential instalation on this forum, there is plenty info here.
What tires are on the car?
Secondly...what tires are you running?
This is incorrect...2008 models do not have LSD. If I'm not mistaken, it's 2010+ that have LSD. Second, 20 degrees is way too fricken cold for tires. If you're talking 20C, then I think that's almost like 70F, which isn't very hot either....warm up the tires.
lots of power, cold tires, no grip.
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
try better/wider tires, check air pressure , drop psi down a bit if necessary, feather the throttle until you have traction instead of just slamming on the gas right off the bat.
I ran a 13.0 @ 111 on all-season tires and significant wheel spin in 50-something degree weather. But my car did NOT fishtail, just spun off the line even with traction control + VSC off. In very cold weather the wheels do spin but not to the extent you are describing. Car should not do the same thing when the temperatures are warmer, not as much at least.
My videos may help, your F may do the same.... I'm running stock sizes all around, Conti DWS
My wheelspin at the track:
Significant wheelspin halfway through 2nd gear at 2:40.....low 40 deg temps
I have an '11 and it always slips/pulls/chirps going into 2nd gear. It did it with the stock tires and it does it now with my Hankooks. It's only a split second thing and the LSD kicks in but it seems its over before it even happens.
Care to explain how the car is fishtailing if the "E-Wannabe-LSD" isnt working and the car is only spinning one tire?
I am not the most experienced drag racer, but I don't think you want to go pedal to the floor when you launch in first gear. Your going to make up for this by getting a perfect shift from first into second. Its going to take some time, but there is a sweet spot to launching the car, and use m- mode and be sure to be in sport mode as well! Theres several factors that could be causing your car to fishtail such as the tires and temperature. But if all else is good, I blame you being in auto mode for this and also turn off traction control (sounds counterintuitive) but try it.
Its a lot of horsepower your trying to put down and wider tires couldn't hurt.
Its going take some practice, and like others have mentioned there is an "electronic" LSD in the car which I've heard is not very good in comparison to a mechanical LSD, which shouldn't affect straight line acceleration pulls anyways.
Every car is a little different and has its own sweet spot...figuring out where that is actually is the fun part.
