Header & Exhaust questions
Old 06-17-13, 11:15 PM
zojirushi
zojirushi's Avatar
I noticed the same thing when I had my headers installed.
Originally Posted by IsFast3r
I went through this when I recently did my PPE headers a few weeks ago. The gaskets you have circled are correct 17173 and 17173a (they are actually the same gaskets left and right). Remember to use your CL discount if buying from sewell.
Gasket 17410B I did not get and I do not think is necessary as lowrideraz said. The sensors are on the oem headers and for whatever reason is not shown in the diagram above. If you look at the ppe headers you will see a open slot for the o2 sensors. Since I bought them new the installers didn't bother to try to remove the old ones, so they are still on the oem headers.
What I found a lil odd was that the gaskets 17173 were like a composite looking plastic whereas the installer game me back the oem gaskets and they were metal. Anyone else that had this done notice this?
Good luck OP! Your gunna love it
Old 06-18-13, 06:59 AM
PhiDeltBee
PhiDeltBee's Avatar
Originally Posted by lowrideraz
Actually The Simulator, there is only one, Connects from above the the ECU wire connectors under a flip open box under the hood. It is installed from above, and complete instructions come with the headers. Once installed, unless you know what your looking for, the installation is invisible.
Lou
Correct, I should have worded that differently. They connect into the ECM (like 4 wires or something) and trick the readings of the O2 sensors.
Old 06-18-13, 04:12 PM
RCB
RCB's Avatar
Originally Posted by mr2envi
Mine was modified to tap into the two downstream o2 sensors. More simpler installation because of no stripping or clipping of the ecu harness. No code so far
That's a nice idea
I wish I did that pnp setup on mine. I think I'll try that on my next install.
DonTN
IS F (2008-2014)
59
04-16-20 06:33 PM
B00M3R
02-27-17 07:44 PM
kammrk
Lexus Vehicles Classifieds
06-20-16 05:20 AM
CodyJames
IS F (2008-2014)
16
05-13-13 08:14 PM
PPEHeaders
Performance
33
12-05-09 04:08 PM
Quick Reply: Header & Exhaust questions
