Wiper Blades
Old 06-30-13, 11:35 AM
zapa
zapa's Avatar
Default Wiper Blades
So my wiper blades are starting to wear out and I wanted to see if there was any option better than the stock ones. So for those of you that replaced them what did you go with or what would you recommend.
Thanks
Zapa
Old 06-30-13, 11:55 AM
Bigcloud
Bigcloud's Avatar
I went with the top of the line rain-x ones. Wayyyy better than stock.
Old 06-30-13, 12:14 PM
zapa
zapa's Avatar
what were they called?? Latitude or fusion.
Old 06-30-13, 01:44 PM
Boma
Boma's Avatar
I'm using the Bosch Marathon blades, works good for me. If you want to go with Rain-X, get the Latitudes.
Old 06-30-13, 02:57 PM
rapsquared
rapsquared's Avatar
I like the OEM refills, cheap from sewell
Old 06-30-13, 04:29 PM
2011ISFNY
2011ISFNY's Avatar
I got the rain-x , works great but the coverage area of the edges aren't great. The edge of the blade doesnt curve to the windshield. Not sure if its the ones I brought or if others have this issue.
Old 06-30-13, 08:07 PM
shyguyF
shyguyF's Avatar
Bosch ICON, i've been using on gx470(not on the F) for 2 years, still work great.
Old 06-30-13, 08:28 PM
ISFWes
ISFWes's Avatar
If you clean your blades often with Isopropyl alcohol. You won’t need to change them till they tear. I havent changed mine in a couple of years.
Old 06-30-13, 10:02 PM
bnizzle87
bnizzle87's Avatar
Agreed. Such an easy install, and definitely more coverage than the OEM blade.
Old 07-01-13, 10:54 PM
avgj0F
avgj0F's Avatar
...and Rain-X or equivalent would help too. Mine are still original from day 1.
Old 07-02-13, 07:57 AM
zapa
zapa's Avatar
I ended up ordering the rain x latitudes. My blades have been on the car for 43k miles and I clean them with IPA all the time.
Old 07-02-13, 08:10 AM
scamsel
scamsel's Avatar
interesting, i do enjoy but i've always felt rain-x accelerates deterioration of the rubber. perhaps i've just had bad luck....
i have heard that aquapel is really good and lasts much longer on the windshield, but i have not tried yet.
Old 07-02-13, 08:49 AM
tgui
tgui's Avatar
I put rain-x spray on my windshield. I can't tell if I have bad wiper blades!
That stuff is amazing!
Old 07-02-13, 08:59 AM
XpediencY
XpediencY's Avatar
Doesn't the F have built in water repellent coating into the front windshield like the LS?
Old 07-02-13, 01:01 PM
tgui
tgui's Avatar
I haven't a clue. All I know is water beads and falls off much faster since application.
Quick Reply: Wiper Blades
