2012 F center bore size help!
Hi all. I recently purchased a set advan gt and the hub on those are 73.1 and I'm wondering what is the size of the center bore on our cars? Thanks in advance!
60.1mm is the correct size. rings need to match the wheels because some have retention groves for snap rings. If its flat then just get some machined down or order some in.
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
![](https://www.clublexus.com/forums/signaturepics/sigpic106840_3.gif)
