Will this 18" square setup fit?
Old 08-03-13, 08:18 PM
Reaper21
Reaper21's Avatar
Default Will this 18" square setup fit?
Looking to run the following square setup. Will they rub?? I'm pretty sure the rears will be fine, I'll probably add 5mm spacers too. I'm more concerned with the fronts. Thanks.
RAYS Gram Lights 57DR
18x9.5 +38 All around
255/35/18 Dunlop Direzza DZ101
Old 08-03-13, 08:24 PM
Reaper21
Reaper21's Avatar
If the fronts don't fit I'll just go with the 8.5" with 225/40/18 up front.
Old 08-03-13, 08:27 PM
Murph145
Murph145's Avatar
Yea that should fit as long as they clear the calipers. Y do u want a square set up.
Old 08-03-13, 08:28 PM
4TehNguyen
4TehNguyen's Avatar
255 is way too wide for the front, 235 is probably the widest you can get for the fronts
Old 08-03-13, 08:37 PM
MK4Sup_isF
MK4Sup_isF's Avatar
I'm on 19x10 +30 with 245 35 for my front and I still have plenty of room to go up to 255. You will be just fine. I have seen guys with 19x10 +33 on 255 for the front
Old 08-03-13, 08:55 PM
Reaper21
Reaper21's Avatar
No reason other than I just like the concavity of the 9.5". I'm still not sure, I may end up going staggered with the 8.5 up front.
Old 08-03-13, 09:10 PM
CalitriSC
CalitriSC's Avatar
255s are an easy fit up front! I had 20x9.5s with 255s up front as well as 19x10 +33 up front with 255/35s and no issues. With 18s it will be even easier.
Old 08-03-13, 10:09 PM
Murph145
Murph145's Avatar
^ yea nothing hard about 255s up front
Old 08-03-13, 10:23 PM
CalitriSC
CalitriSC's Avatar
^ No sir, i could have had 265s up front lol.
Old 08-03-13, 10:39 PM
ilv1004s
ilv1004s's Avatar
9.5 +38 is no problems with the guards
Old 08-04-13, 10:38 AM
Reaper21
Reaper21's Avatar
What do you guys think about these specs being flush? And by flush I mean just straight even with the fender, no pokage or anything.
Old 08-04-13, 10:55 AM
MK4Sup_isF
MK4Sup_isF's Avatar
it's depending on how low you are also, due to natural negative camber as you lower your car. You will be fine with 9.5 +38. I'm on 10 +30 front with -2.7 camber and my wheels sit pretty much flush. Guys rolling with 10 +25 poke slightly
Old 08-04-13, 10:59 AM
MK4Sup_isF
MK4Sup_isF's Avatar
BTW, 255 35 18 tires will change your overall rolling diameter to 25.1", that is over 1" smaller than stock of 26.2". I don't think that is a goood idea. Suspension and ABS are going to be affected.
Old 08-04-13, 11:02 AM
Reaper21
Reaper21's Avatar
Thanks for the info MK4 - I'm actually going to be swapping my suspension to BC coils. How is it going to affect the ABS?
I knew they are going to have a smaller diameter but I didn't really think that would be a problem for anything.
Old 08-04-13, 11:59 AM
CalitriSC
CalitriSC's Avatar
Pretty simple, get 255/40/18.
Quick Reply: Will this 18" square setup fit?
