Will these wheels fit my ISF?
would this be better adjustment for the same wheel specs?
WHEEL DESIGN : LE10
FRONT WHEEL SIZE : 19/9.5/+25 Tire (235/35/19)
REAR WHEEL SIZE : 19/10.5/+32 Tire (265/30/19
CENTER FINISH : BRUSHED CLEAR
LIP FINISH : POLISHED
HARDWARE FINISH : TITANIUM
Lip Depth:
42mm = 1.65inch Front
48mm = 1.88 inch Rear
WHEEL DESIGN : LE10
Lip Depth:
IS350s have more rear fender clearance and less front fender clearance, unless the article I read was bogus.
I know the front has less clearance due to the ISF having wider front fenders. I had read that the ISF rear end is actually a little bit wider in the suspension (hubs stick out a bit further). If I’m wrong, Lance or one of the OGs will correct me.
I think it’s true, because I have both cars and my ISF wheels look more sunk in on my is350. So wheels that clear and IS350 rear fender may not clear an ISF.
nismo4life
18
05-27-13 09:27 AM
Ownagespot
SC- 1st Gen (1992-2000)
31
12-21-12 06:46 PM
SuicidnS13
GS - 1st Gen (1993-1997)
08-22-11 11:54 PM
