How often do you get alignment/balancing?
How often does your F get an alignment/balancing? It's been a while for me (over 10k miles), I found no need for it since the car tracks fairly straight and feels stable at highway speeds. Do you guys take it to the dealer or a small shop? Also, what are the alignment specs for maximum tire life?
I had mine done shortly after I bought it at about 17k at the dealer and they told me the first owner had never had it done in all the records they had. Not sure if it really needed it but my dad had just had a blowout on the highway and driven a half a mile on just the rim so it definitely didn't hurt to have it done while they were putting a new wheel and tire on.
alignment and balancing is only supposed to be done when you get wheels or suspension components changed. Anything more than that your just wasting money. its good to get suspension and wheel components checked every 20-30k miles, but it cost very little. Sears usually does it for free! (thats if you really trust them with your car, I trust the one near me). Dealerships usually do it for free during service but outside of service, cost like $20-30 bucks
Changing the wheels does not change your suspension geometry. A 19" wheel and a 17" wheel will have the same camber/toe/caster if you changed each other out without touching your suspension.
Checking your alignment is necessary for proper tire wear over the lifespan of the tires. Road conditions may alter your alignment (potholes, dips, bumps on road) as well as over the duration of the car the alignment may change as your suspension components wear out. So depending on how often you drive, you may want to check your alignment every few months to see if anything has changed. (slight camber change will change toe, not good for tires)
FYI by the time you realize your toe is off, you may have done more wear on your tires than you have expected. Just because the car feels like it drives straight, doesnt mean the alignment hasn't changed.
I would disagree with most points in your post.
Changing wheel size doesn't affect suspension geometry which is true but balancing your wheels is necessary each time you mount a new tire to a new rim (balancing NOT necessary when mounting rim to car just so there is no confusion on what i am saying)
Checking your alignment is necessary when changing suspension components from wear due to road conditions BUT if your camber or toe changes over the time span of a few months then that means you would need to check the quality of suspension components to drastically change your toe/camber. Most shops if not ALL shops guarentee alignment only up to a year but a lot of cars can go longer without a realignment with proper suspension components. Yes you should have it checked often but its not required to spend the $100 bucks a year for re-alignment hence me saying its a waste of money. You do an alignment only when necessary.
Under stock car conditions, i think its fair to say that there is no such thing as Balancing your suspension or Alignment for your wheels/tires
I don't disagee with you but I am right with the understanding that "Alignment" is suspension components, and "Balancing" is wheel components.
Balancing and alignment is completely different.. balancing is NOT part of an alignment. Having an unbalanced wheel does not change your toe or camber.. the suspension (all control arms/bushing/balljoints etc) has an effect on your alignment.. balancing does however have an effect on tire wear, but so does a bent wheel. Like i said.. when you get new wheels/tires, you balance the wheels/tires and mount it onto the car. Alignment isn't necessary after that.
Toe changes even a little during a span of a few months depending on how much you drive and road conditions. In Cali we have horrible roads, toe changes with each pothole, train track, bump you drive over.. even if its slight.
Shops have a guarantee only because other shops do (to stay competitive). Seriously, its a headache for them to have a guarantee due to road conditions, driving habits and aged suspension components. I do say you should definitely get it checked, but I'm not saying you'll need it every 10,000-20,000 miles.. it really depends on all the factors I listed. I had my alignment change a week after I had it done because I wasn't paying attention and I hit a pothole.
Stock car or modded car does not change.. you can have a screwed up alignment with stock cars as much as modded cars.. this is why dealerships have alignment racks, they are there for stock vehicles.
Re-Read my post dude, This is exactly what I'm trying to explain. Like I said, Its with the understanding that "Alignment" is suspension components, and "Balancing" is wheel components. Two totally different services.
Again exactly what im trying to explain from my original post. Getting suspension check frequently is necessary but having a full 4 wheel alignment is not 100% necessary during ANY interval. Its an open ended interval as it, you only do it when necessary!
Sorry if I mis-interpreted what you were saying.
To answer the OPs question, Allign:
1. With every tire change.
2. If you visually can see an unusual wear pattern developing in the tires tread.
3. Any suspension modification or suspension part change.
4. If you have hit a pothole with enough force to make a large bump. This is subjective, but you can make the determination.
Lou
Lou
Lou
Lou
Bushing issue. Fig's bushing will fix that.
Ho Motorsports
There's no set interval for alignment. If you alter any part of the suspension components, then you'll definitely need to check the alignment since it'll change the suspension geometry. If you hit a pothole hard enough, there's a change your alignment might go out of spec.
Make sure you check your tire pressure regularly. Inconsistent tire pressure plays a big part in abnormal tire wear and diminished performance.
Terrance
Terrance
