Battery Fitment Issues
So, my batter died and I bought the Duralast Gold - 24-DLG from Autozone to replace the OEM one I had. The plastic casing doesn't fit right and I can't seem to get the battery bracket that sits on top of the battery back on because it seems like the battery itself is too tall.
Anyone else have this issue? I'm thinking it'll be fine to not have the battery bracket on but wanted to confer with the experts .
Thanks,
Jon
Thanks,
Jon
Group 24 is certainly the correct size for any IS.
It seems the search function of this forum has decided to take a hike. I found my old thread on Google.
https://www.clublexus.com/forums/is-...ggestions.html
Lou
Lou
Thanks,
Jon
Thanks,
Jon
I ordered the optima last week. It came in two days. It fits great and works great. Also a lot lighter than the OEM battery. By almost 25lbs I believe. I put it in and it didn't fit. It it comes with a stand that you snap into the bottom of it and it fits like a glove. It also retains the plastic surrounding as well.
Here is the link
http://www.amazon.com/gp/aw/d/B006QH560A/ref=redir_mdp_mobile?ref_=pe_385040_30332190_pe_175190_21431760_M3T1_ST1_dp_1
Lou
Lou
On previous cars, I usually buy Die Hard. On the F, none of the Die Hards fitted. One was too short for the cover and one was too high for the attachments that the wires mount on. I even tried the DieHard golds. The tie downs will not install properly on any of them.
I was able to find the green top Interstate battery at Firestone.
Here is the link
http://www.amazon.com/gp/aw/d/B006QH..._M3T1_ST1_dp_1
Here is the link
As far as what fits (not performance) just what fits in a Lexus IS, a Group 24 battery, that is the correct replacement battery for the Lexus ISF. Brand, model or whatever does not matter! The BCI, Battery Council Internal, sets battery sizes, and they don't vary from manufacturer to manufacturer. Other sizes may work, but they will not fit properly.
This thread may be of interest:
https://www.clublexus.com/forums/gs-...placement.html
BTW, I have a Group 24 Bosh Battery in my F.
Lou
Lou
I found that it was the heights that affected me. Even though Group sizes I tried were all 24, the dimensions were different. Here are the dimensions:
DieHard Model 50324
Group Size: 24
Height (in.): 7.6
Item Weight (lbs.): 41
Length (in.): 10.25
DieHard Model: 51324
Dimensions:
Group Size: 24
Height (in.): 9
Item Weight (lbs.): 40
Length (in.): 10.8
Power Ratings:
Cold Cranking Amps (CCA at 0 deg.F): 650
Reserve Capacity (RC): 115
Interstate MT-24:
Product ID: MT-24
Cranking Amps: 750
Cold Cranking Amps: 600
Voltage: 12
Capacity: 75
Termination: Common Code A
Weight: 39.2
Width: 6.88
Length: 10.25
Height: 8.75
Plates: 24
DieHard Model 50324
Group Size: 24
Height (in.): 7.6
Length (in.): 10.25
Dimensions:
Group Size: 24
Height (in.): 9
Length (in.): 10.8
Power Ratings:
Interstate MT-24:
Product ID: MT-24
Cranking Amps: 750
Voltage: 12
Capacity: 75
Weight: 39.2
Width: 6.88
Length: 10.25
Height: 8.75
Plates: 24
See attached Pages from the BCI Battery Replacement Data Guide.
202mm = 10.24”
173mm = 6.81”
225mm = 8.86”
BTW, Height includes the posts.
10.8" would equate to 274mm - I see no battery that is that length.
Lou
202mm = 10.24”
173mm = 6.81”
225mm = 8.86”
Lou
diamondmit
04-02-09 03:17 PM
