New isf pulling to the right?!
Ok guys I printed out both papers and going to take my 2012 In Tommrow just for that reason and my amp.
I don't kno what's she will say or the tech hopefully they fix it I'm getting quite irritated with there lack of "trying" !
This is what happens to your stock tire ( one of em ) if your brand new isf pulling to the right ![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
Will be taking it to lexus of Sacramento tomorrow....
please print out your alignment sheets and make sure your toe is close to zero for the fronts.
you will also want to look at this https://www.clublexus.com/forums/is-...eo-inside.html
check the thread below for alignment
https://www.clublexus.com/forums/is-...alignment.html
after you mentioned it that's what I did , looked behind the wheel on both sides , everything looks good , no sign of wear what so ever, every plastic, metal etc looks new... so it is definitely something else
So my result so far yesterday came in shop Forman came for a drive with me to check if it was pulling.
Came back they told me to leave the car got a Nissan Altima as a loner that's about the only disappointment so far
At 5pm got a phone call from my rep and she said there going to have to order a few parts and if I was ok to leave the car for the rest of the week so hopefully when I get it back it will be all done with.
I'm wondering if I could take te Nissan back and get a lexus...
Please let me know if the shop you're taking it to fixes the right pull issue, and what was replaced.
I have taken the 2011 ISF twice to West End in Southern CA (subframe moved + alignment on the 2nd time), 3 times to the dealer (they only set it to the "green" zone), and still have a heavy pull to the right.
Have right pull issue from purchase: on the original OEM PS2 tires, on brand new PSS at all 4 corners, swapped front side to side, nothing helps....
Everyone is saying "radial pull" but I don't buy that....
Thanks in advance....
Tech Info Resource
Sad to say, but this is not unusual at all for any 2IS.
Tech Info Resource
