Sikky vs PPE Header Comparison with Results
this post is a joke ... you FEEL more response from changing headers that on dozens of dynos from mult members have not yielded more than 5 whp apart from Sikky header up or down, the headers have very similar results. Which you can not feel in your butt and that dyno is clearly busted.
Numbers aren't tampered with since they cross at about 5252 like they all do. The dyno was just broken I am not basing my conclusions on what I felt (it's an opinion), you are joke if you think that's why I posted this. However I posted this so you can see the difference with the numbers and once the dyno is fixed and we will see the results then. Obviously the PPEs don't make up ~150whp, duh. Multiple members also haven't tested with the same dyno, cars, mods, conditions and etc. this post is to show the difference between the two with the same car, the same mods and the same circumstances.
Now if you want to debate build quality and ease of installation between Sikky & PPE, there's like a 10 page thread on that going already.
But how can we tell anything from this post since the dyno was broken? I think we probably all clicked to see if the dyno shows anything other than a +/- 5whp difference between Sikky and PPE, but given your post, we don't actually know anything at all. I appreciate the fact that you're willing to do the experiment, but I just think you posted too prematurely. Now if you want to debate build quality and ease of installation between Sikky & PPE, there's like a 10 page thread on that going already.
![Dance](https://www.clublexus.com/forums/images/smilies/dance.gif)
I am having the same "left turn rattle" as described by everyone else. I reached out to Sikky and they were extremely accommodating. Not only did they send me a new (and supposedly approved) passenger side header, they also sent me their sway bar for the extra labor for the switch. They stayed in touch with me throughout the whole process as well. i am having the updated passenger side header installed tomorrow morning. I will post an update as soon as it's in. Hopefully i'm not disappointed again.
Edward, how's it going these days? Where did you have the headers installed, Elite? Were you able to "feel" (AKA: But Dyno) much of a difference from stock?
This time my car put down 397whp/365wtq and temp. was 84. I will have the sheet uploaded once they email me it.
I'm 99% certain there is little to no difference in power between the two and a dyno comparison though on the same car still doesn't solidify results. The dyno is good for comparing results immediately for tuning but to compare headers just doesn't work. For example I can get readings of plus or minus 30 HP in between pulls depending on what the ECU is doing with timing.
I think I've dyno'd my car more than anyone else (120+ pulls) and my final conclusion is this car certainly makes power with exhaust mods but making comparisons of any kind should be taken with a grain of salt.
That is true but we still consistently got better numbers with the PPEs. The numbers I posted were the best pulls out of about 6 runs for each. If a 15whp gain is negligent in this case I am not sure why people go running off thinking the JoeZ intake tubes make the alleged 5whp. I made the thread just to put it out there so people can see the difference between the two on the same car, nothing more nothing less. Anyone can take it for what it's worth.
And darbs the dyno was working fine with my first pulls with the Sikky headers, it got messed up when they were doing some tuning with a F10 M5 in between my tests.
I will however at this point say that if I were to buy set of headers and I wasn't within driving distance to Baltimore (JE Import) that I too would buy the PPE headers. It's odd that all the sets installed at JE are fine, but hearing too many cases of issues when installed elsewhere that it would be a no brainer to not go with the PPE.
I am still confident that if you were to put the SIKKY headers back on again you'd see different results. You're ECU is constantly adapting and with all the WOT runs it was adjusting more and more and by the time PPE headers were installed it was closer to "optimized." We could debate this forever, but I'm sticking to my belief based on dozens of drag strip runs, way too many dyno pulls and seeing how close they compare to others such as ToothDoc and Lowrideraz.
I will however at this point say that if I were to buy set of headers and I wasn't within driving distance to Baltimore (JE Import) that I too would buy the PPE headers. It's odd that all the sets installed at JE are fine, but hearing too many cases of issues when installed elsewhere that it would be a no brainer to not go with the PPE.![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
Luckily for me I am out in Arizona for a month so PPE is sort of right down the block from me. I can't speak on the rattle/fitment issue either since I never ran into that problem. I am not sure if it's installation error or just lack in consistency with the production of headers but I am glad I got my PPEs.
