PPE Full Exhaust System with Dual Mode Muffler
#272
The Maker
Custom mufflers using higher grade german packing, custom options like cats and resonator deletes.
We have one in stock if interested.
Mike
Mike
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
#275
The Maker
so get it with no cats or resonators. IMO that note would not suit my taste longterm.
__________________
#277
More Picts. And Video added: Sorry for the Crappy Video. I don't know what that background noise was But you get the idea. If you look closely at the muffler on the right hand side, you can see the valve open and close.
http://youtu.be/R-t0-_U4ucQ
Lou
Lou
Figs, and or Lou,
Regarding the switch for the dual mode, what route did you use to send the wires to cabin of the car? just curious.
also buying the exhaust comes with a switch correct? i could probly splice another switch for single and dual mode...
wanting to order one (but cant order the exhaust for a few months at least)... huh
#278
Figs, and or Lou,
From us.
-Josh
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
#279
Figs, and or Lou,
The kit comes with the switch and harness. It is an OEM switch that matches perfectly to the other switches on the dash.
808newbie (12-27-16)
#280
say if I decided to drive out to you guys for a ppe header & catback install, how long would install take from start to finish?
#282
-Josh
__________________
Orange County, CA
Orange County, CA
#284
The Maker
We used the firewall grommet since it has a provision to have a pass through wire and it will not require the carpet to be adjusted, If you do use the o2 grommet I would make sure its sealed back up with silicone as it sits on the bottom of the car open to the elements (somewhat).
We came up with the OE switch for a seamless integration and the best appearance once installed and we ended up tapping into the laser cruise power circuit on the driver's side as the power source, otherwise, the next best "switched" circuit is on the other side of the car. If you order from us you get the best first-hand support from a company that has installed and improved the overall integration of this product, detailed instructions, and some video as well. It's not difficult. Mike
__________________
