F Emblems on front fenders
Got a question about the LH and RH F emblems on the front fenders.
If I order new set F emblems for the front fenders from Sewell, does anyone know if they come with a temple to properly locate them on the ISF front fenders ?
If it doesn't it, what's the best way to locate them ?
I believe there's no locating holes on the front fenders.
Thanks.
Thanks.
When you remove the oem fender emblems there should be two holes behind it.
When installing a replacement, there should be two pins at the back of the emblem which fit into the holes on the fender.
Pretty much impossible to screw up alignment as you have to push the pins into those 2 holes for it to stick back onto the fender.
Unless I'm missing something here?
I did mine 2 weeks ago and didn't have to even look at the emblem when re-installing it.
Is this the emblem you're referring to?
Ok.
I have never seen an F without the fender emblems, so I wasn't sure if there are pins behind it.
My shop showed me a new F-sport emblem and it doesn't have any pins at the back, so I thought the F emblem is the same.
As usual, the forum members are a great resource.
I can save my time making a template.
