Anyone Running Spacers on Stock 2012+ Wheels?
Old 01-18-14, 02:09 PM
Rossi
Rossi's Avatar
Originally Posted by Capn
(Tien Springs, H&R Spacers on 2009 IS-F)
this photo made me get my spacers
Old 01-18-14, 02:42 PM
scamsel
scamsel's Avatar
Originally Posted by Rossi
I have 15mm all around with 245/35/19 and 275/30/19 tires, plus my front is lowered 0.7 inch.
No issues, the front is tight, I could not go any wider. Rear is fine.
For you on wider rims, but stock tires I would not go over 15mm, that is just me.
nice, so what tires do you run pss? 15mm all around is what capn had in the pics you posted of his car?
also how is your front lowered, and is it lowered in the front only?
Old 01-18-14, 02:57 PM
CalitriSC
CalitriSC's Avatar
I had 25mm with my stocks and it sat perfect.
Old 01-18-14, 04:17 PM
ULTSISF
ULTSISF's Avatar
+1 15mm all around
Old 01-18-14, 05:05 PM
jat0223
jat0223's Avatar
Are you guys with 15mm spacers installing extended studs? what model of H&R spacers should I get?
Old 01-18-14, 05:52 PM
ULTSISF
ULTSISF's Avatar
Def extended studs Don't install anything without that.
Old 01-18-14, 07:11 PM
Rossi
Rossi's Avatar
Michelins PSS 245/35/19 & 275/30/19
Eibach Springs FRONT only
H&R 15mm all around.
I believe Capn has same tire size / spacer combo, lowered on teins.
Old 01-19-14, 05:15 PM
Vervish
Vervish's Avatar
Looks great..any fender mods (rolling/cutting) required with 15mm spacers. Thinking of doing spacers at same time i do swift springs.
Old 01-19-14, 07:06 PM
LOLM3
LOLM3's Avatar
I ran 15mm spacers all around with my 2012 wheels I'll try and find some pictures.
Old 01-19-14, 11:10 PM
shahir18
shahir18's Avatar
I am about to install swift springs on the front of mine as well
please do, also... do you think it can be possible to put 20mm spacers on the rear or 15mm is enough?
Old 01-20-14, 01:17 AM
LOLM3
LOLM3's Avatar
Only pictures I could find. 15mm is more than enough
Old 01-20-14, 07:39 AM
Vervish
Vervish's Avatar
Very nice..any fender mods?
Old 01-20-14, 09:59 AM
Marn
Marn's Avatar
15 mm rear with swift springs. 20mm will most likely rub without a fender roll.
Old 01-20-14, 10:10 AM
shahir18
shahir18's Avatar
Nice Pics, thanks!
Awesome detailed picture, I appreciate it... would you have a pic of the front as well?
Also, do you suggest installing the rear springs or would just the fronts suffice and give it an even gap all around?
Old 01-20-14, 10:18 AM
ISFGEORGE
ISFGEORGE's Avatar
Install all 4 springs. It will sit just right. no rear sag whatsoever. Yes I am speaking from experience on my 2012.
Originally Posted by "that boy"
Nice Pics, thanks!
Quick Reply: Anyone Running Spacers on Stock 2012+ Wheels?
