Lexus Certified ISF brake issues
Old 02-19-14 | 12:44 PM
Vervish's Avatar
Vervish
Originally Posted by scamsel
the last sentence in that link leaves you hanging, as I don't see any procedures!
"The recommended procedures below should provide you with the information you need to select the bed-in procedure appropriate for your application."
also, does one still follow a bed in procedure when just replacing pads?
Originally Posted by Vervish
I would try re-bedding the brake pads. Sometimes deposits on the pad itself can cause a slight vibration.
Instructions here: http://www.zeckhausen.com/bedding_in_brakes.htm
FYI...see above.
Old 02-19-14 | 12:46 PM
Vervish's Avatar
Vervish
If you are replacing the pads with the same manufacturer and the same model, no, you don't need to bed them the same as you would if you are changing manufacturer and compound.
I never knew this..I always bed them. Good info.
oscar55773
IS F (2008-2014)
02-27-18 10:05 PM
2URGSE
IS F (2008-2014)
03-24-16 04:26 AM
FBTO
IS F (2008-2014)
18
11-06-12 12:18 PM
STRAN
IS F (2008-2014)
15
06-22-12 02:37 AM
superYaris
IS F (2008-2014)
125
02-08-10 09:03 PM
