When to replace brakes
I currently have around 27k miles on my F & I was wondering when everyone was replacing there pads/rotors.. I know theres a huge thread on brakes but havent seen anything about mileage. Just wondering what the F drivers are getting out of their pads/rotors.. &&&& it seems like figs 2 piece rotors with hawks + plus pads are the way to go?
__________________
![](https://www.clublexus.com/forums/signaturepics/sigpic167102_16.gif)
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
Just check by looking at your pads when the wheel is off or through the spokes of your wheel.
The rotors need to be measured but at 27k most likely its ok unless the car had track time.
The car is heavy and depending on how you drive, everyone will wear out their brakes differently.
From my personal experience, Hawk pads are all noisey and overpriced.
Tech Info Resource
Track use won't make the rotors too thin. They'll crack beyond service limits before they get too thin. AMHIK.
so I guess im way over due for my brake pads front and rear. OEM pads, second set at only 27k miles.. I never track, I drive aggressive sometimes but not often to be replacing brake pads that often. & I guess I need new rotors too... I got all this checked out by a shop that has no intentions to rip me off..
So now.. what route for rotors and pads should I go with?
__________________
Orange County, CA
Orange County, CA
http://speed-freaks.net/i-11694367-l...ront-axle.html
anyone have experience with these?
Im looking for something that has less oem dust, good or a better grab, and fade doesn't really matter since I don't track.. and rotors I have no clue what I want, something good.
__________________
Orange County, CA
Orange County, CA
Tech Info Resource
Spend your money as you see fit, but I think you'd be wise to measure the rears at the very least.
Tech Info Resource
Not like MB. There are tiny metal tabs attached to the pads. When they contact the rotor (with 1mm of pad remaining) they make a loud screeching sound. So you won't get a dash indication, you'll hear a loud squeal from the brakes as an indication your pads are at the wear limit.
Or you can do what I did at the track, and tap your brakes in the pits, hear the metal on metal clank, and know your racing laps are over for the weekend, and it's time to put the street pads back in to drive home.
This is what a fully worn out brake pad looks like:
![](https://iexzgw.bn1303.livefilestore.com/y2p5pGSeYkec0GkCkyNfXTXSA3A1NpPIlpZutdJYtfND5zPVVqbHproO8fyiI4sMOEgQbCQvCa9h88UJw6__jQRBOj1d5dKEVay9Ij-_tBETm4/IMG_3280%5B1%5D.JPG)
The rest looked like this:
![](https://6wkfaw.bn1.livefilestore.com/y2pZUXblGxyp8LkoiSeUircwXxqdLjR-VjBxZZ0g7cZZWKcwcUe2hScBo8VqVPlPWjF1ccvkfSOwcooKoCwXf-6X-XsMu6pwNy6PVmiwSVBwKs/IMG_3281%5B1%5D.JPG)
Yes, the disc was still in fine shape after this.
OK, but I have nearly 100k miles on my F and I'm still on the original rear rotors, and that includes track weekends with full race pads. The rear brakes on this car hardly ever get used unless you're making the eLSD work big overtime.
Okay thanks guys..what are the measurements for front & rear rotors, bare requirement til i need to replace? Probably need pads again though. Suggestion for something with a lot less brake dust, great grab (better then oem) &
__________________
Orange County, CA
Orange County, CA
Fade isnt really a problem since i dont track, maybe once or twice LATER. I was leanin towards stoptechs or project mu ns400
__________________
Orange County, CA
Orange County, CA
