Weird ISF Transmission Issue
I have read through some of the treads out there about transmission problems but none sound like mine so I thought I would post and see if anyone else has experienced this and what they did or found out???
I bought my 2009 ISF back in Sept 2013 with 25K miles on it...it is a CPO car (good thing)...anyway this has happened to me about three times now.
It happens after the car has sat for a day or so. It starts off shifting fine as I creep through my neighborhood (25-30 MPH)…then as I accelerate (has happened only when I am kind of getting on it) onto the main road it won’t shift…it is like it gets stuck in 2nd or 3rd gear (not sure which gear and I have started keeping my display set so I can see which gear if it happens again)…I then try to get it to shift by taking my foot off the accelerator and then hitting it again and again. All three times it eventually shifted and then after that “no problems” even if I get on it. Other than those three times in 5 months, the transmission works awesome…I am confused![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
I take my car to the dealer for maintenance, so is there something specifically I can ask them to check…computer wise???
My car exhibits that behavior when the oil is cold, if I try to paddle shift near the redline it won't go, no problems once it warms up. I don't use the paddles until the engine is warm, the auto gets the job done till then
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
My 08 does this as well when it's cold..... it's annoying as hell, but perfectly normal in my experience. I will usually switch over to manual mode and upshift when it tries to hold the gear.
Thanks...I will pay attention to the oil temp but I was not in sport mode or using the manual shifting when this happened...I was using the basic automatic and letting the car shift...I was just getting on it a little bit...like to pull out into traffic aggressively...not even thrashing it when this happened all three times???
I usually let her idle in the morning for about a minute and then its about a two minute gingerly cruise to the freeway on ramp. I haven't ever noticed anything strange with the tranny getting on the freeway in auto
Tech Info Resource
Mine does this all the time when the gearbox is cold. Step on the gas a little harder, or use sport mode and hit the gas a little harder. I live near the top of a hill, so my drive away is always down hill first. No chance to get heat in anything.
I appreciate all the replies and have been watching my Oil Temp and my gear selection...it has not happend recently and I did notcie that it takes a while for the oil temp to get to two bars even here in Florida where it is high 70's today. So I guess I am buying into what everyone is saying...Thanks.
