Wish to up grade the sound quality on my ml system!
Need help , what are the common cures for the crappy sound on the ml of the F , I wish it was louder and cleaner ,any inputs on the subject would be greatly appreciated!
Disconnect the factory subwoofer and use a singal converter like an LC2i to be able to hook up an aftermarket subwoofer and amp. The actual sound quality of the ML system is decent but lacks low end. The ML system actually gets fairly loud and by adding an aftermarket sub the system cannot cut low end to prevent distortion, which is what you are experiencing.
I actually did this and it's very simple. The sub is located in the rear deck. Pull the speaker cover up and unscrew the sub. Disconnect the clip and use them for your audio signal into the lc2i. Run your power, ground and remote wires for the amp and lc2i and your set to hook up an aftermarket sub. There is a entery point behind the battery to run your power wire into the cabin.
i recently upgraded the stock 8" sub to a JL audio sub/amp combo using the audio control lc2i and so far so good. mL speakers arent the best ive had but theyre enough for me not to spend ~$1000 to upgrade speakers all around.
one 12" sub is making something between my rear seats and trunk rattle.
Installed sub JL 10W7 + XD600/1 + LC2i + trunk sound deadening into 2012 ISF, a lot better than before. But the volume and Sound Quality of the speakers are not that great. Speakers are still too "Bright" and not balanced at all...
Looking to replace speakers with Focal/Hertz with JBL MS8/Audison Bit/PS8 LOC.. but this seem like a difficult task and not sure what to do.
Anyone gone beyond adding a sub?
As for speaker sound quality that is subjective to the listener. I personally think all lines of focal speakers are bright. I tried numerous brands and always found myself going back to morel.
