PPE header & CEL
Hello, on saturday i took my car out and suddenly after parking the car got a little shaky and eventually the famous cel popped up. I'm assuming this can be a result of my ppe headers and such. The roads were a little wet when i drove it. With that being said, i scanned the codes and basically got:
Random misfire detected —> P300
Misfires on cylinder 2/4/6/8 —> codes p0302/4/6/8
System too rich bank 2 —> p0175
o2 sensor signal stuck rich bank 2 sensor 1 —> p2198
I've driven this car on and off for about two months now after the header install with no problems at all but none of the times were the roads as wet as on saturday. I've searched around but haven't seen anyone with o2 codes in conjunction with misfires (unless i just suck at searching lol)
I'll be bringing it to a shop soon which a friend of mine will look at but I want to figure out some stuff to let him know to look at. I know it can be wiring touching the header maybe or the o2 sensor crapped out but i'm pretty sure water has something to do with this. Can anyone chime in with what may be the problem? Any help is appreciated.
After a year and a half, I got a CEL with my PPE headers. I got the P2241 Bank 2 Sensor 1 oxygen sensor.
I suppose my O2 sensor is shot. Just have to figure out which side - right or left. Whether is the one on the header or the midpipe on the Borla.
It just happened today. It works normally but it won't engage first gear, traction control, VDIM, etc. are all disabled. So now I can drift and spin out w/o having to turn off traction control. LOL
I just got the readout from the Lexus dealership but they won't fix it because of legal issues and having no cats.
I'm assuming it's the cheap O2 sensor and not the A/F sensor so it's probably on the midpipe. Don't know if I should just replace both or really try to figure out which one it is. So far I haven't been able to find out online yet. Still searching...
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
We see bad AF (Air Fuel Ratio) sensors on toyotas cause this sort of issue quite often. So in conclusion you are going to first be looking at the wiring on the bank 2 front sensor, and if all appears well I would suspect a bad sensor or a defective o2 simulator if that is what you are running.
I8ABMR, if you have the link can you link me to that thread so i can read it?
Just reset your ecu, mine went away. & if you need new o2 sensors , pm me, i have brand new oem ones.
__________________
![](https://www.clublexus.com/forums/signaturepics/sigpic167102_16.gif)
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
The O2 conditioner does not disturb the front O2 sensors so you can rule that out.
I would change out the sensor, reset the ECU and re-check.
Lol seriously fml.
__________________
Orange County, CA
Orange County, CA
